Mesa 5i24 mesaflash : No 5I24 board found
11 Aug 2016 12:20 - 11 Aug 2016 15:26 #78606 by erasmo
Hi I have a problem - after programming 5i24 with bitfile using command
sudo ./mesaflash --device 5i24 --write 5i24_25_sv12im_2x7i48.bit
5i24 stopped responding and is not visible using lspci
command
sudo ./mesaflash --device 5i24 --readhmid
gives output:
No 5I24 board found
I did full power cycle and I swaped pci port nothing have changed.
Red Led is ON all the time
What should I do? Can anyone help?
Last edit: 11 Aug 2016 15:26 by erasmo.
11 Aug 2016 14:36 #78619 by PCW
Is the 5I24 you have a -25 model?
What OS and mesaflash version did you use?
I sounds like either the bitfile was not appropriate or somehow the EEPROM got corrupted
I have heard about a problem with 64 bit OSes and mesaflash, possibly you have run into this
You should be able to recover by selecting the other EEPROM
BUT that's the last chance (without JTAG) so the problem needs to be determined
_before_ the backup EEPROM is also corrupted
The first step is to find out what happened
11 Aug 2016 15:00 - 11 Aug 2016 15:02 #78622 by erasmo
Replied by erasmo on topic Mesa 5i24 mesaflash : No 5I24 board found
Chip number:
XC6SLX16
FTG256DIV1249
EEProm Memory
25P16VP
My system Ubuntu 10.04 32 bit
Last edit: 11 Aug 2016 15:02 by erasmo.
11 Aug 2016 15:05 - 11 Aug 2016 15:16 #78623 by PCW
Ahh, you tried to put a -25 bitfile in a -16 card
The bitfile you want is 5i24_16_sv12im_2x7i48.bit
Here is what I would do to make sure the second EEPROM is kept safe:
1. Arrange your PC so you have easy access to the 5I24 card
2. Move the EEPROM jumper to the secondary position
3. Power on the PC (red lights should go out)
4. Move the EEPROM jumper back to the Primary position
5. Run the correct mesaflash command
Last edit: 11 Aug 2016 15:16 by PCW.
The following user(s) said Thank You: erasmo
11 Aug 2016 15:21 #78624 by erasmo
Thank You it worked.
11 Aug 2016 19:54 - 11 Aug 2016 20:04 #78644 by erasmo
Hi now I have next problem - 7i65 analog outputs doesnt work.
My pid.output goes to mesa-7i65.0.analog.0.out but it does nothing, no voltage on AOUT0
mesa-7i65.0.enable.0.out is set
Encoders are working fine, watchdog is disabled for testing purposes
What am I doing wrong?
Last edit: 11 Aug 2016 20:04 by erasmo.
11 Aug 2016 20:08 #78645 by PCW
The config you are using is not suited to a 7I65 (its meant for 1 or 2 7I48s)
For a 5I24-16 with 1 or 2 7I65s you would want 5i24_16_2x7i65.bit
11 Aug 2016 20:11 - 11 Aug 2016 20:12 #78646 by erasmo
I also have 7i44 connected to P4 will it run using 5i24_16_2x7i65.bit ?
or do I have to compile my own designated bitfile?
Last edit: 11 Aug 2016 20:12 by erasmo.
11 Aug 2016 20:15 #78647 by PCW
That needs a new bitfile
I'll see if I can get to it today
12 Aug 2016 17:52 #78680 by PCW
Moderators: PCW, jmelson
Time to create page: 1.344 seconds
