Mesa 7i84 setup
- BBowers
- Topic Author
I have a Hardinge CHNC that I would like to get going again with the original drives and resolvers.
I have the following cards;
5i24_16 (loaded with 5i24_16_rmsvss6_8.bit firmware)
______7i49HV (connected to P4 of the 5i24)
______7i44 (connected to P2 of the 5i24)
_____________7i84 (connected to channel 0 of the 7i44)
_____________7i84 (connected to channel 1 of the 7i44)
_____________7i73 (connected to channel 2 of the 7i44)
I am new to Linux and it has taken some time but I can see the resolver working that I have hooked up to the 7i49hv, and a switch that I have hooked up to the 7i73 using “Show Hal Configuration” and the “watch” tab.
That just leaves the 7i84 cards to get working.
Both cards have the jumper in setup mode and a 5v power supply to the I/O section.
Each card has a yellow LED light at the top and bottom lit.
I believe they need to have the file 7I84R14.BIN loaded on to the 7i84 cards but not sure if I use Mesaflash, Hostmot2, or UFLBP and what the syntax would be.
- Thank you received: 5334
1. To be jumpered in operate more ( W2 "left" )
2. To have field and VIN power (W1 "left", +8 to +32V in TB1 pins 1,2,3,4, ground on TB1 pins 6,7,
There is no need to change 7I84 firmware (unless you have 7I84s that are more than 3-4 years old )
- BBowers
- Topic Author
Thanks PCW.
BBowers wrote: I have a Hardinge CHNC that I would like to get going again with the original drives and resolvers.
That's a lot of IO. I have only 1 7i84 on my CNC lathe and still have many channels free. (I am using exactly the same Mesa hardware as you otherwise, except that I also have a pair of 8i20 as the servo drives)
- BBowers
- Topic Author
I was hoping that the original motor drives would burn up when I powered them up so I could go with modern system like you but they seem fine. I wont be doing production work with it so the 200 inch/min speed shouldn't bother me too much.
Its nice to know that you have already got one going. I know I will have some questions for you in the future if you don't mind.
