Latency to run 7i76E
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Jul 2017 07:49 #96261 by tecno
Latency to run 7i76E was created by tecno
What kind of latency numbers is a minimum to run 7i76E?
AC servos with Step/Dir control.
Cheers
Bengt
22 Jul 2017 08:40 #96265 by rodw
Replied by rodw on topic Latency to run 7i76E
I've seen PCW quote that hes had machines running fine with 120 usec latency. (USFF PC)
  • tecno
  • Platinum Member
  • Platinum Member
22 Jul 2017 08:50 #96268 by tecno
Replied by tecno on topic Latency to run 7i76E
Hi Rod,
is that base thread numbers?
22 Jul 2017 09:32 #96269 by rodw
We don't use a base thread on the 7i76e, only a servo thread so ignore base thread latency. PCW would have been quoting servo thread.
  • tecno
  • Platinum Member
  • Platinum Member
22 Jul 2017 09:40 - 22 Jul 2017 09:45 #96270 by tecno
OK, that means my PC:s are waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay to slow or ??
Have to find new MOBO's that fit mini-ITX or close to that size as I have lack of space.
Any suggestions to what to buy?
Last edit: 22 Jul 2017 09:45 by tecno.
22 Jul 2017 10:11 #96272 by rodw
Ouch!
This is what I'm using with Linux Mint 18.3.
www.gigabyte.com/Mini-PcBarebone/GB-BXBT-1900-rev-10#ov
Latency for a few minutes while writing this.....
I've also got the same PC in a N3160 which is the next iteration of the J1900 chipset and it works fine.
PCW linked to a Zotac Dual NIC PC which I could not source in Australia. if i bought another PC, I would probably get a dual NIC J1900 one like this on aliexpress This looks suspiciously like the one CandCNC's Command CNC uses (which is LinuxCNC based)
Remember it is mandatory to discard the internal Wifi cards and use a USB wifi dongle. If you don't your latency will worse than what you have now.
22 Jul 2017 10:15 #96273 by rodw
This is the thread I based my selection on. Some of the links have gone
forum.linuxcnc.org/38-general-linuxcnc-q...ff-pc-s?limitstart=0
Search for USFF on the forum, you might find a bit more info
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
22 Jul 2017 12:24 #96278 by Todd Zuercher
Replied by Todd Zuercher on topic Latency to run 7i76E
Before you give up.
Have you tried any thing to improve the latency of the PC you have? Turning off power saving in the bios, hyperthreading, C states...
Have you tried different settings for ISOLCPUS? What MB do you have now?
  • tecno
  • Platinum Member
  • Platinum Member
22 Jul 2017 12:31 #96279 by tecno
www.jetwaycomputer.com/NC91.html
Tried everything possible in BIOS, ACPI must be enabled otherwise very bad latency numbers.
22 Jul 2017 12:45 #96281 by PCW
Replied by PCW on topic Latency to run 7i76E
Also you need to run the latency test with the base thread disabled
(your latency numbers are meaningless since you have a base thread running faster than the CPU can service it)
For the latency test run:
latency-test 1ms 1ms
For the latency histogram, run:
latency-histogram --nobase
Moderators: PCWjmelson
Time to create page: 0.362 seconds
