7i76e and 7i73
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Oct 2017 19:17 #100982 by Mike_Eitel
7i76e and 7i73 was created by Mike_Eitel
Read a lot. But I need some help.
I used the stretch ISO and changed to master. And 2.8 is running.
I have 7i76e and connected 7i73, connected via cable according to Norberts pdf.
In synaptic all available Mesa is installed, but there is nothing for 7i76 etc.
Downloaded files from Mesanet and copied by hand in lib/fiirmware/hm2/767.
Run a configuration via pncconf. Axis is starting.
But I can not find the pins for the 7i73 in hal-meter etc.
Also the automaticaly configured .bit file is not in the lib directory.
Nor do I see a bit file for a 7i76e/7i73 combination.
What did I miss or where can I get the missing bit files.
THX in advance
29 Oct 2017 19:24 - 29 Oct 2017 19:26 #100983 by PCW
Replied by PCW on topic 7i76e and 7i73
There is no specific bit file for the 7I73, It ( like all sserial cards) is supported by any 7I76e bitfile
If you see the 7I76 pins but not 7I73 pins this suggests a cable wiring error
I could also be disabled in the driver config line in the hal file
Last edit: 29 Oct 2017 19:26 by PCW.
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
29 Oct 2017 19:27 #100984 by Mike_Eitel
Replied by Mike_Eitel on topic 7i76e and 7i73
Wow that was a fast answer.
I'll go and check now.
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
29 Oct 2017 19:36 - 29 Oct 2017 19:41 #100985 by Mike_Eitel
I used a tested ethernet cable. Cut and connected. I believe it is ok.
Whats else could it be?
Last edit: 29 Oct 2017 19:41 by Mike_Eitel.
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
29 Oct 2017 19:44 #100986 by Mike_Eitel
2. Try to send Image.
29 Oct 2017 19:46 #100987 by PCW
As I mentioned before, It could be the driver command line in the hal file
could still be a cable issue ( crossover cable or non EIA/TIA 568B colors )
7I73 jumpering ( if you moved any from the default jumpering )
What LEDS are illuminated on the 7I73?
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
29 Oct 2017 19:58 #100988 by Mike_Eitel
Murphy's law. You are good!
In deed, The cable has other colour distribution. Grrr.
Now i remember having read that there existed another norm..
One LED is red. Hope i did not grilled the card.
Will change the plug.
Thx
29 Oct 2017 20:04 #100989 by PCW
I dont think i've seen any non EIA cables but have heard they exist...
Not likely anything was damaged (hard to do with just 5V)
24V wiring is another matter...
The red LED is expected if you have power but no communication (it signals a watchdog fault)
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
29 Oct 2017 20:18 #100990 by Mike_Eitel
Made a new plug on the old cable.
Restarted and now i see pins!
THX
Now i can work on transfering from 7i47 to my new electronics.
Also 7i47 never let me down.
29 Oct 2017 20:29 #100991 by PCW
Great, glad you got it going
Moderators: PCW, jmelson
Time to create page: 0.165 seconds
