7i76e and 7i73
9 years 3 days ago #100988 by Mike_Eitel
Replied by Mike_Eitel on topic 7i76e and 7i73
Murphy's law. You are good!
In deed, The cable has other colour distribution. Grrr.
Now i remember having read that there existed another norm..
One LED is red. Hope i did not grilled the card.
Will change the plug.
Thx
9 years 3 days ago #100989 by PCW
Replied by PCW on topic 7i76e and 7i73
I dont think i've seen any non EIA cables but have heard they exist...
Not likely anything was damaged (hard to do with just 5V)
24V wiring is another matter...
The red LED is expected if you have power but no communication (it signals a watchdog fault)
9 years 3 days ago #100990 by Mike_Eitel
Made a new plug on the old cable.
Restarted and now i see pins!
THX
Now i can work on transfering from 7i47 to my new electronics.
Also 7i47 never let me down.
9 years 3 days ago #100991 by PCW
Great, glad you got it going
4 years 1 month ago - 4 years 1 month ago #253035 by furynick
Replied by furynick on topic 7i76e and 7i73
I know this is an aged topic but I'm facing the same problem.
I connected my brand new 7i73 on my 7i76e with two different network cable and still getting communication error after trying these steps :
  • wire as explained in 7i73 manual
  • swap Tx+/Tx-
  • swap Rx+/Rx-
  • swap Tx/Rx
  • swap Tx+/Tx-
  • swap Rx+/Rx-
    I switched off 7i76 between each test but didn't started LinuxCNC.
    I guess hardware communication between 7i76e and 7i73 don't need LinuxCNC to be started, am I wrong ?
    My hal file contains sserial_port_0=20xxxx.
    Does anyone have an idea on what I'm doing wrong ?
Last edit: 4 years 1 month ago by furynick.
4 years 1 month ago #253043 by PCW
1. The picture shows the TX and RX pairs swapped
(go by the colors in the 7I76 manual)
2. You need to start LinuxCNC for communications to be initiated
Moderators: PCW, jmelson
Time to create page: 0.392 seconds
