reflash 7i76 connected with 7i92 possible?
- Thank you received: 2172
03 Dec 2017 22:41 #102633
reflash 7i76 connected with 7i92 possible? was created by cmorley
I need to upgrade the firmware on the 7i76.
I'm using a 7i92, which doesn't seem to work to flash the sserial
it doesn't see the 7i76 when hostmot2 is loaded with setup speed baud.
First - is this possible I can't see any reference to using cards other then the 5i25. 6i25...
If it should work, then i'll give more detail to what I have done so far...
Chris M
Chris M
- Thank you received: 5296
03 Dec 2017 23:37 - 03 Dec 2017 23:42 #102637
Replied by PCW on topic reflash 7i76 connected with 7i92 possible?
I don't think I've tried this particular combination but it certainly should work
something like ./updatess-eth 7i76 7i92 0
Note that the updatess-eth script assumes a 10.10.10.10 Ethernet FPGA card IP address
Last edit: 03 Dec 2017 23:42 by PCW.
04 Dec 2017 01:16 #102642
Replied by cmorley on topic reflash 7i76 connected with 7i92 possible?
Yes I got it to work thanks.
I suspect I didn't get the jumper set correctly the first time.
One thing is the readme mentions using commands such as:
./updateess .....
That looks like a bash command yet the update files are HAL files.
I did it by hand in a halrun environment.
Maybe I missed something there but anyways thanks it helps when you know it is supposed to work
Chris M
./updateess .....
Chris M
04 Dec 2017 01:36 #102643
Actually that's a bash file that creates a hal file from a template and then runs it with halrun
You may not have power cycled after moving the jumper (the bash file reminds you to do this)
- Thank you received: 4647
08 Dec 2017 02:01 #102754
There are bash scripts if you get the driver update file from Mesa.
I probably should change the setsserial manpage to reflect that.
Replied by andypugh on topic reflash 7i76 connected with 7i92 possible?
Time to create page: 0.160 seconds
