Questions on PID tunning using Mesa 8i20 drive
- Henk
- Thank you received: 92
14 Dec 2017 12:32 #103107
by Henk
Replied by Henk on topic Questions on PID tunning using Mesa 8i20 drive
Hi Andy
I was also under the impression that this would be risky but gave it a shot anyway and it seems to be working OK. The linear scales are Heidenhein LSxxx with EXE converters so they should be quite reliable.
There is no Encoder on the motor, only a 3-phase tacho-generator and the hall-sensor vane. I ran the motor in "h" mode and couldn't really see a difference.
Ill let you know if I pick up problems.
Setsserial worked without problems, thanks
Henk
Henk
- Henk
26 Nov 2018 14:51 #121371
by Henk
Hi
i used another 8i20 for a 4th axis build to use on my MAHO MH600C. This time im using a fanuc red-cap motor but replaced the serial pulsecoder with a normal ABZ incremental encoder and running BLDC in qi mode.
I am having issues initializing BLDC. Sometimes it will act as expected and rotate slowly until index is found and in that case all is well and works fine.
Most of the time though the init-done pin will go high at the same time that the init pin goes high and no initializing sequence takes place. In this case the motor commutation is incorrect and it does not function.
I am at a loss here and considering noise on the index from the i=encoder but in halscope all seems ok (at the highest sampling rate)
Attached my ini and hal files
Any input is appreciated
thanks
thanks
- Thank you received: 5334
26 Nov 2018 15:11 #121372
Replied by PCW on topic Questions on PID tunning using Mesa 8i20 drive
I'm not sure why you would replace the serial pulsecoder with a standard encoder since the serial pulsecoder already has a absolute commutation track and is supported by HostMot2
In any case if you have noise on the index, you could try:
1. Turning on the encoder filter bit for the affected channel
2. Possibly lower the encoder sample rate
If the encoder filter bit is on, all signals (A,B,I) must be present 15 sample periods to be recognized. If the filter bit is off, the encoder inputs must be present for only 3 sample periods to be recognized
- Henk
26 Nov 2018 15:21 #121373
by Henk
Hi PCW.
I didnt have the original pulsecoder. I got the motor without one so i fitted a 1000ppr ABZ as second best.
The encoder filter bit is set to 1. Not sure how to alter the sampling rate thouh....
What is strange is that when i comment out the index-enable connection to bldc, and leave it in qi mode, the motor rotates endlessly in search of the index which is expected.
But with that line active, it is as if the index or a false index is found immediately.
Thanks for the quick reply
26 Nov 2018 15:25 - 26 Nov 2018 15:27 #121374
Did you try inverting the index polarity?
You can also verify index hardware operation by "setsing" the signal that carries the index enable
and then had rotating the shaft to verify the the signal is only cleared at the index position
Last edit: 26 Nov 2018 15:27 by PCW.
- Henk
26 Nov 2018 16:18 #121375
by Henk
Hi.
Index enable is low as soon as lcnc is launched. Setting this signal high in halshow and rotating the encoder works as it should. It goes low as soon as the index is detected.
If i initialize after setsing index enable true the motor homes as it should and runs with acceptable performance.
So. How do i make sure index enable is true before init pin goes high? Adding sets a-index-enable 1 to the hal file doesnt seem to work.
Henk
Henk
26 Nov 2018 16:37 #121378
It looks like the thread order is wrong
Normally you should have:
hardware read
all processing
hardware write
but you have the BLDC component before any of this
hardware read
all processing
hardware write
- Henk
26 Nov 2018 17:58 #121384
by Henk
Hi Again
ok, so i have changed the first part of the .hal file to have the following:
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
setp hm2_[HOSTMOT2](BOARD).0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s,pid.a
loadrt classicladder_rt numPhysInputs=50 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10 numBits=50 numWords=50
loadrt oneshot names=machine-on,machine-off
loadrt toggle names=mode,blockdel
loadrt mux16 names=foincr,raincr,spincr
loadrt gearbox
loadrt scale names=spindle-cl-in,spindle-cl-out,selected-jog-incr-cl-out
loadrt or2 names=x-pos,x-neg,y-pos,y-neg,z-pos,z-neg
loadrt message names=slideway-lub messages="Slideway Lubrication pressure not reached"
#loadrt sp_encoder_z
# for 4th axis#######
loadrt bldc cfg=qi
loadrt sum2
loadrt timedelay
addf hm2_7i92.0.read servo-thread
addf bldc.0 servo-thread
addf sum2.0 servo-thread
addf timedelay.0 servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf classicladder.0.refresh servo-thread
addf machine-on servo-thread
addf machine-off servo-thread
addf foincr servo-thread
addf raincr servo-thread
addf spincr servo-thread
addf mode servo-thread
addf blockdel servo-thread
addf gearbox servo-thread
addf spindle-cl-out servo-thread
addf spindle-cl-in servo-thread
addf selected-jog-incr-cl-out servo-thread
addf x-pos servo-thread
addf x-neg servo-thread
addf y-pos servo-thread
addf y-neg servo-thread
addf z-pos servo-thread
addf z-neg servo-thread
addf slideway-lub servo-thread
#addf sp-encoder-z servo-thread
addf hm2_7i92.0.write servo-thread
But, a-index-enable stays false after startup.
It works if i add the sets a-index-enable in the postgui hal file though
loadrt trivkins
loadrt hostmot2
loadrt gearbox
loadrt bldc cfg=qi
loadrt sum2
loadrt timedelay
26 Nov 2018 19:00 #121389
Replied by andypugh on topic Questions on PID tunning using Mesa 8i20 drive
pin in bit init if (personality & 0x05) == 4
"""A rising edge on this pin starts the motor alignment sequence. This pin
should be connected in such a way that the motors re-align any time that
encoder monitoring has been interrupted. Typically this will only be at machine
power-off.
The alignment process involves powering the motor phases in such a way as to
put the motor in a known position. The encoder counts are then stored in the
\\fBoffset\\fP parameter. The alignment process will tend to cause a following
error if it is triggered while the axis is enabled, so should be set before the
matching axis.N.enable pin. The complementary \\fBinit-done\\fP pin can be used
to handle the required sequencing.
net init4ax <= classicladder.0.out-14 => bldc.0.init
At what point in the sequence doe bldc.0.init get set?
power-off.
- Henk
27 Nov 2018 05:24 #121450
by Henk
The init pin is set after powering up the drive DC power. The 8i20 enable is also asserted at the same time, but a-enable (pid) is left low until init-done is high.
I managed to solve the problem last night. When lcnc starts up, a-index-latch is low, and in this case BLDC seems to detect the index immediately after init goes high without successfully homing the rotor.
When I sets a-index-enable true in halshow before initiating, the rotor homing works as it should and all is well.
Adding the sets a-index-enable true to the main hal file did not result in a high signal directly after launching lcnc, but adding this line to the postgui hal file did.
I have the following line in the hal file
"net a-index-enable bldc.0.index-enable"
Maybe this should have been :
"net a-index-enable <=> bldc.0.index-enable"
I did not try this though but it is working as it should now.
Thanks for steering me in the right direction. problem solved.
Much appreciated.
Henk
Much appreciated.
Henk
Time to create page: 0.235 seconds
