Does the 7i92-7i76-7i74 firmware support SSI ?
8 years 10 months ago - 8 years 10 months ago #103270 by Cornflakes
Hi
I need to connect 6 absolute encoders.
Or I need special version?
How many ports support SSI in this configuration ?
Thanks!
Dmitry
Last edit: 8 years 10 months ago by Cornflakes.
8 years 10 months ago #103289 by PCW
There's no standard firmware for this but it should be easy to cobble together.
As far as SSI channels go, I'll have to see how many fit.
I'll try to get to this today or tomorrow sometime.
8 years 10 months ago #103298 by PCW
freeby.mesanet.com/7i92_7i76_7i74_ssid.bit
8 SSI channels fit without a problem
( I was probably thinking about BISS which is substantially larger than SSI )
The following user(s) said Thank You: Cornflakes
8 years 10 months ago #103330 by Cornflakes
PCW,
Thank you for support!
Dmitry
8 years 9 months ago - 8 years 9 months ago #104252 by Nick
Hi, PCW
It's hard to find firmwares with ssi support. They are not included into Support software packs and can be only found at some rare posts at the forum (with secret links to freeby.mesanet.com/something_ssi.bit :) ).
Are there any for 5i25+7i77 (+7i74) and 7i92+7i77 (+7i74)?
Most of times I'll need 3-6 ssi encoders but sometimesonly 1 will be enough.
Last edit: 8 years 9 months ago by Nick.
8 years 9 months ago - 8 years 9 months ago #104269 by PCW
Its not a common config but I can make them, I'll try and get to this sometime this week.
Last edit: 8 years 9 months ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.066 seconds
