Multiple MESA FPGA Cards in one system
- silden
- Thank you received: 3
14 Jan 2018 22:15 #104476
by silden
Multiple MESA FPGA Cards in one system was created by silden
Hi All,
I'm pretty new to linuxcnc and the MESA Cards, but I did a lot of reading and came up with one question.
Namely if I can have multiple MESA FPGA Cards in a single system.
The reason I'm asking is that I want to upgrade my current system from a LPT to MESA and I'm not sure weather I should buy a card that fits my current needs or a bigger one to account for future upgrades.
I would like to use 6I25 or 7I92 and later add another one to increase the capabilities of my system.
I read through some posts regarding the hotmos2 configuration and it stated that you load a certain firmware onto a 5I25.
In short, can I use multiple FPGA Cards of the same model or do I have to use different models and if it is even possible?
How should the configuration look like for multiple FPGA PCIe or ethernet cards.
Thank you in advance,
Denis
Denis
- Thank you received: 5296
14 Jan 2018 22:39 - 14 Jan 2018 22:40 #104477
Replied by PCW on topic Multiple MESA FPGA Cards in one system
You can use as many as 4 of each card type ( and have multiple card types in a system ),
but it's seldom required since a single 5I25 or 7I92 can provide more I/O than most machines
need. For example a 5i25 + a 7I76 provides 5 axis of step/dir outputs, 32 digital inputs. 16 digital outputs
a spindle encoder input, an analog spindle interface plus a serial expansion channel. You can
double this IO by adding a second 7I76 and extend even further by using the serial expansion channels
so systems that require more than one FPGA card are very rare
Last edit: 14 Jan 2018 22:40 by PCW.
- silden
15 Jan 2018 04:09 - 15 Jan 2018 04:10 #104494
by silden
Replied by silden on topic Multiple MESA FPGA Cards in one system
Thank you for your reply.
This makes the decision easier.
BTW
I don’t believe that I will need more than a 6i25 can give me, but I know me and I am already planning to install linear encoders on each axis and I like to use a Tool changer on this machine.
But I will go with the 6i25 for now and extend the system as I go.
Thank you again for your help.
Denis
BTW
Denis
Last edit: 15 Jan 2018 04:10 by silden. Reason: typos
Time to create page: 0.372 seconds
