MESA card - what difference between voltages
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Feb 2018 14:19 #105574 by aleksamc
Hi, all.
We bought out first mesa card 7i92m + 7i76.
I didn't catch up, what difference between Vin and Field voltage. I can make it separate with jumper.
Cards will operate servo drivers with Step/dir signals of 5V, but other Enable inputs will be 24V.
Explaine me please this difference. What should I chouse?
08 Feb 2018 15:21 #105576 by PCW
if you are using 24V you can tie VIN and field power together
step/dir signals are always 5V
You typically only use separate field power and VIN when you need 5V field outputs/inputs
  • aleksamc
  • Platinum Member
  • Platinum Member
09 Feb 2018 09:01 #105623 by aleksamc
Replied by aleksamc on topic MESA card - what difference between voltages
Thanks for your answer, PCW. To Vin I always need to wire 24V? What this input meens?
09 Feb 2018 13:12 #105629 by PCW
VIN supplies the isolated side regulator and can be 8V to 32V
so if field power is between 8V to 32V you can tie VIN to field power
If you have 5V field power, ( or firmware that allows field power to be turned off )
VIN must come from another source.
The following user(s) said Thank You: aleksamc
Moderators: PCWjmelson
