xilinx ise
- billykid
- Thank you received: 82
16 Feb 2018 16:46 #106025
by billykid
xilinx ise was created by billykid
Hello,
I installed xilinx ise 14.7, I should edit the file "7i80hd_16_svst8_4.bit" to adapt it to 7i80db 16.
before going crazy to do it I would like to know if you do so with the free license.
or if someone has already done it and can help me.
Thanks in advance
Mauro
Thanks in advance
Mauro
- billykid
22 Feb 2018 23:20 #106358
by billykid
Replied by billykid on topic xilinx ise
Nobody ?
- Thank you received: 2172
23 Feb 2018 01:21 #106368
Replied by cmorley on topic xilinx ise
You might just try asking peter from mesa if he will make the firmware for you/
Chris M
Chris M
- phillc54
- Thank you received: 2100
23 Feb 2018 02:18 #106371
by phillc54
Replied by phillc54 on topic xilinx ise
This
may help.
- billykid
23 Feb 2018 11:22 #106381
by billykid
thanks to you
I saw the link and tried but it gives me errors .. but I have not yet figured out if the downloadable version of ise 14.7 generates the .bit file or you have to buy the license.
I'm sorry to bother Peter, he's already working hard for everyone ..
I would rather learn with ise
Mauro
Mauro
- mozmck
- Thank you received: 59
23 Feb 2018 14:29 #106384
by mozmck
Replied by mozmck on topic xilinx ise
You do not need to buy an ISE license, the free webpack works just fine.
The following user(s) said Thank You: billykid
- Thank you received: 5296
23 Feb 2018 15:20 #106392
Replied by PCW on topic xilinx ise
Basically to make a new configuration for a already existing card, you make a new pinout file
The pinout file determines which modules are built and how they are connected to the physical FPGA pins
If you dont want to install webpack I can build a bit file for you but you would have to supply a pinout file that has your desired pinout (plus I need the target card/FPGA size)
Pinout files all start with PIN and end with NNN.vhd when NNN is the number of GPIO pins of the particular card:
34 = 5I25,6I25,7I92
42 = 4I74
48 = 7I43,7I93
51 = 7I76E,7I96,7I97
68 = 7I80DB
72 = 5I20,5I22,5I23,5I24,6I24,7I80HD,7I90
96 = 5I22
144 = 3X20
34 = 5I25,6I25,7I92
42 = 4I74
48 = 7I43,7I93
68 = 7I80DB
96 = 5I22
144 = 3X20
- billykid
23 Feb 2018 16:28 - 23 Feb 2018 16:30 #106401
by billykid
thanks Peter,
my card is 7i80DB-16, since the 7i40 have the db connector I have to redo the right connections but it's not a problem for me.
for example J2- 7i40 J3 -- 7i40 J4 -- gpio J5 -- gpio
maybe even if it supports a stepgen in one port
this is what I need.
Thanks again
Mauro
Thanks again
Mauro
Last edit: 23 Feb 2018 16:30 by billykid.
- billykid
02 Mar 2018 13:15 - 03 Mar 2018 14:27 #106845
by billykid
I basically need the svst8_4 pin for 7i80db 68 pin not 72. but it is not found .. if someone has already done it simplifies my life
thank you
Mauro
ps
Peter are in your hands
thank you
Mauro
ps
Last edit: 03 Mar 2018 14:27 by billykid. Reason: add image
- billykid
07 Mar 2018 10:15 #107071
by billykid
I finally managed to change the pins !!!
maybe I will not have done in the best way but it works!
Time to create page: 0.462 seconds
