how to setup mesa 7i83
03 Mar 2018 14:41 - 03 Mar 2018 15:08 #106877 by PCW
Replied by PCW on topic how to setup mesa 7i83
What version of LinuxCNC are you using? That looks really wrong
EDIT, actually now that I think about it, that's all correct
if you enable the ports but no sserial device is found the ports revert to GPIO
If you disable the ports (with x) or missing sserial_port token they are not probed so still
show up as sserial at that point in initialization
What you data does show is the the card was not found
This is most likely because of missing power somewhere
(7I74 or 7I83)
Also note that I said the signal name would look like
hm2_5i25.0.7i83.0.1.analogout0
the actual name depends on the channel and port
(use halcmd show pin *7i83*)
Last edit: 03 Mar 2018 15:08 by PCW.
The following user(s) said Thank You: thang
04 Mar 2018 07:14 #106893 by thang
Replied by thang on topic how to setup mesa 7i83
i'm using linuxcnc 2.8 pre with ubuntu 16.04 and preempt-rt.
I didnt wire all pin of 5i25 --> 7i74 because i dont have DB 25 male-male cable, i just wired gnd and some pins. I will try connect all pin and check power again.
06 Mar 2018 09:17 #107022 by thang
it's my fault, i didnt connect pin tx3 and rx3 .Now, everything is working well. thank you very much for help.
Moderators: PCWjmelson
Time to create page: 0.103 seconds
