Operating a Solenoid Air Valve from 7i76e
  • DanMN
  • DanMN's Avatar Topic Author
  • Senior Member
  • Senior Member
09 Mar 2018 20:54 #107173 by DanMN
I'm not 100% confident in my knowledge of electronics, so I thought I'd run my math past the experts here.
I'm running a 7i76E with 24v field power, and I want to drive an air valve rated at 5.4 watts. If I'm correct, that should pull 225mA from a suitable output, like TB6 pin 17 -- and be safely under the 350mA limit. Is this correct?
Also, as I presently have this valve wired to a momentary contact manual switch, it needed a flyback diode. If I interpret the 7i76e manual correctly, the output should be flyback protected already. Is that the case in my application?
Any other recommendations for me?
Thanks,
09 Mar 2018 22:42 #107175 by PCW
225 mA is safe but you must have a flyback diode
across the solenoid (band to 7I76 output)
  • DanMN
  • Senior Member
  • Senior Member
10 Mar 2018 00:03 #107177 by DanMN
Replied by DanMN on topic Operating a Solenoid Air Valve from 7i76e
Thanks for the confirmation. I actually just stumbled across a thread where you mentioned a ~60mA threshold for a relay. I'm guessing the solenoid is a similar inductive load, so that makes sense.
I'm now beginning my second build based on another 7i76e. I can't say enough great things about your cards. Really fantastic products.
Moderators: PCWjmelson
Time to create page: 0.298 seconds
