Huanyang vfd HY0D7543B
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Mar 2018 22:27 #107519 by Mike_Eitel
Huanyang vfd HY0D7543B was created by Mike_Eitel
It is for my mills spindle and I bought that vfd some years ago.
Connected and tested manusly via frontpannel. All fine. Now I want to connect lcnc.
I use 2x signals plus 1x Estop.
Mainly want RUN and FOR/REV + ESTOP and use first three multi-purpose inputs.
According to deliverded paperbook
PD044 = 1
PD045 = 5
PD046 = 13 ( in newer/actual pdf it seems to be 9)
Working nearly as expected.
I need to revert direction while running. Fx. for threading.
Tested until now only with switches on cables.
1. If I start RUN without FOW/REV it turns forward. Taking RUN away it stops. Perfect!
2. Connecting FOW/REV while running no reverting happens. Dammed!
3. Starting with both singals it turns backwarts as expected. Good.
Has anybody an idea how i can have 2. without disabling RUZ for a moment?
THX Mike
19 Mar 2018 03:08 #107529 by jmelson
Replied by jmelson on topic Huanyang vfd HY0D7543B
Do you have an analog signal to the VFD for speed control? I rigged a lowpass filter component to slow the change of the speed command, and when the speed goes through zero the forward signal flips off and the reverse flips on.
Jon
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
19 Mar 2018 06:19 #107535 by Mike_Eitel
Replied by Mike_Eitel on topic Huanyang vfd HY0D7543B
That is a good approach!
THX
Moderators: PCWjmelson
Time to create page: 0.221 seconds
