motor power 7i40
- billykid
- Thank you received: 82
19 Mar 2018 12:06 #107541
by billykid
motor power 7i40 was created by billykid
Hello,
now I have finished trying the 7i40 and I am very satisfied.
now I have a doubt about the power supply of the motor .. the tests were done with a stabilized power supply at 30 vol 10 amperes.
now if, for example, I use a 24-volt diode bridge and a large capacitor, I go to about 34 volts.
Will this affect pid tuning? perhaps better to stabilize a value?
Thanks in advance
Mauro
Thanks in advance
Mauro
- Thank you received: 5296
19 Mar 2018 16:50 #107551
Replied by PCW on topic motor power 7i40
If the voltage varies significantly, it will affect the tuning (specifically FF1)
A small variation (say 10%) will not typically cause much of an issue
The following user(s) said Thank You: billykid
- billykid
20 Mar 2018 15:31 #107617
by billykid
Replied by billykid on topic motor power 7i40
as with the other drive I had an ammeter to measure the current of the spindle and now with the 7i40 two motors are powered together.
is there a software way to do it?
thank you
Mauro
thank you
Mauro
