MESA 7I52S Encoder board and 7i92M compatibility
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Mar 2018 13:24 #107601 by aleksamc
Does it's OK to use 7i52S encoder interface with 7I92M and 7I76 boards?
I wonder If I can connect encoders to my CNC with this board.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
20 Mar 2018 13:48 #107607 by Todd Zuercher
Replied by Todd Zuercher on topic MESA 7I52S Encoder board and 7i92M compatibility
No, a 7i52S is a 50 pin card and would need to be used with cards like a 5i24, 7i90, or 7i80HD.
With your 7i92, you need to use a DB25 daughter card like a 7i85, or 7i85S.
20 Mar 2018 14:04 #107610 by PCW
There's also the (Ethernet) 7I93 (2X 50 pin connectors)
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
20 Mar 2018 14:28 #107613 by Todd Zuercher
Peter, why doesn't the 7i93 show up in the normal lists of Anything IO FPGA cards on your web store? (Have to click on the "Show All Anything I/O Cards" and there it is the only one listed.)
  • aleksamc
  • Platinum Member
  • Platinum Member
20 Mar 2018 14:51 #107614 by aleksamc
Can I use such configuration 7i93 + 7i76 + 7i52S ?
What you advise Peter to use for 5axis step/dir drives, encoder inputs from that axis and field I/O devises also with ethernet?
If I'll build 5-axis machine in the feauture, I will use such configuration.
And what names of connectors I should search to connect that boards? With LPT interface much easier.
20 Mar 2018 15:21 #107615 by PCW
With a 7I92 and LPT cables the easiest way is probably 2x 7I85S
this gives you 8 axis of encoders and 8 axis of step/dir and 2 sserial expansion channels
Later this year, a better choice would be a 7I95
(Ethernet + 6 axis step/dir +6 axis encoder +6x 5-24V outputs and 24x 5-24V inputs)
The following user(s) said Thank You: aleksamc
  • aleksamc
  • Platinum Member
  • Platinum Member
20 Mar 2018 15:54 #107619 by aleksamc
Thanks for your answer, Peter.
This 7I95 board should be very cool. I think when I'll desided to make 5-axis machine, this board will be in-time.
  • aleksamc
  • Platinum Member
  • Platinum Member
20 Mar 2018 15:56 #107620 by aleksamc
As for 7I85S, I'm not sure it will suits me, because I don't see there field I/O.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
20 Mar 2018 16:14 #107623 by Todd Zuercher
If you used two 7i85S boards you'd need to add a Smart Serial card like a 7i84 for the isolated IO.
If you only need 5 encoder inputs, you could just use the 4 on a 7i65 + the one on your 7i76. (If you don't need a 6th one for something like your spindle.)
  • aleksamc
  • Platinum Member
  • Platinum Member
21 Mar 2018 06:27 #107651 by aleksamc
Will this system (7I95+2x7I85+7i84) will support simultaneous work of 5 axis and 8 axis?
Moderators: PCWjmelson
Time to create page: 0.293 seconds
