MESA 7I52S Encoder board and 7i92M compatibility
- aleksamc
- Thank you received: 67
20 Mar 2018 13:24 #107601
by aleksamc
MESA 7I52S Encoder board and 7i92M compatibility was created by aleksamc
Does it's OK to use 7i52S encoder interface with 7I92M and 7I76 boards?
I wonder If I can connect encoders to my CNC with this board.
- Thank you received: 1467
20 Mar 2018 13:48 #107607
Replied by Todd Zuercher on topic MESA 7I52S Encoder board and 7i92M compatibility
No, a 7i52S is a 50 pin card and would need to be used with cards like a 5i24, 7i90, or 7i80HD.
With your 7i92, you need to use a DB25 daughter card like a 7i85, or 7i85S.
- Thank you received: 5296
20 Mar 2018 14:04 #107610
Replied by PCW on topic MESA 7I52S Encoder board and 7i92M compatibility
There's also the (Ethernet) 7I93 (2X 50 pin connectors)
20 Mar 2018 14:28 #107613
Peter, why doesn't the 7i93 show up in the normal lists of Anything IO FPGA cards on your web store? (Have to click on the "Show All Anything I/O Cards" and there it is the only one listed.)
- aleksamc
20 Mar 2018 14:51 #107614
by aleksamc
What you advise Peter to use for 5axis step/dir drives, encoder inputs from that axis and field I/O devises also with ethernet?
If I'll build 5-axis machine in the feauture, I will use such configuration.
And what names of connectors I should search to connect that boards? With LPT interface much easier.
Replied by aleksamc on topic MESA 7I52S Encoder board and 7i92M compatibility
Can I use such configuration 7i93 + 7i76 + 7i52S ?There's also the (Ethernet) 7I93 (2X 50 pin connectors)
20 Mar 2018 15:21 #107615
With a 7I92 and LPT cables the easiest way is probably 2x 7I85S
this gives you 8 axis of encoders and 8 axis of step/dir and 2 sserial expansion channels
Later this year, a better choice would be a 7I95
(Ethernet + 6 axis step/dir +6 axis encoder +6x 5-24V outputs and 24x 5-24V inputs)
The following user(s) said Thank You: aleksamc
- aleksamc
20 Mar 2018 15:54 #107619
by aleksamc
Thanks for your answer, Peter.
This 7I95 board should be very cool. I think when I'll desided to make 5-axis machine, this board will be in-time.
- aleksamc
20 Mar 2018 15:56 #107620
by aleksamc
As for 7I85S, I'm not sure it will suits me, because I don't see there field I/O.
20 Mar 2018 16:14 #107623
If you used two 7i85S boards you'd need to add a Smart Serial card like a 7i84 for the isolated IO.
If you only need 5 encoder inputs, you could just use the 4 on a 7i65 + the one on your 7i76. (If you don't need a 6th one for something like your spindle.)
- aleksamc
21 Mar 2018 06:27 #107651
by aleksamc
Will this system (7I95+2x7I85+7i84) will support simultaneous work of 5 axis and 8 axis?
Time to create page: 1.731 seconds
