Fried my THCAD-10
- Thank you received: 4138
01 Sep 2018 11:56 #116946
Peter, would you be able to revise this bit file so it exposes the 7i76e UART as you did here:
forum.linuxcnc.org/27-driver-boards/3328...6e-with-uart?start=0
Another member has bought my plasma cutter so I wanted to upgrade to a Hypertherm and see if I can talk to it via the 7i76e's RS422 UART.
Thanks in anticipation.
Replied by rodw on topic Fried my THCAD-10
freeby.mesanet.com/7i76e_76x1dbea.bit
Puts the encoder A input on the 7I76E B pin
Depending on the previous state of the B input in your system, the count direction might change
(so you may need to change the sign of the encoder scale)
- Thank you received: 5308
01 Sep 2018 23:19 #116963
Replied by PCW on topic Fried my THCAD-10
02 Sep 2018 08:02 #116968
Peter, thanks very much.
freeby.mesanet.com/7i76e_dbeapkt.bit
Time to create page: 0.083 seconds
