Hardware & Machines
Driver Boards
7i40 jog acceleration
billykid
Offline
Platinum Member
Thank you received: 82
28 Mar 2018 17:33 - 28 Mar 2018 19:11 #108040
by billykid
sorry if I go back to ask, I adjusted the acceleration perfectly in g0 g1 but in jog mode is very bad.
it accelerates and decelerates too slowly .. I can not understand why.
maybe it should be set apart?
the system is closed loop 7i80 + 7i40.
Mauro
sorry, it was mpg-accels for hb-04 pendant that also affects the jog ..
Last edit: 28 Mar 2018 19:11 by billykid. Reason: solved
Hardware & Machines
Driver Boards
Time to create page: 0.062 seconds
