Intel NUC with mesa 7i76e and some suggestions
- yrsiddhapura
- Thank you received: 5
29 Mar 2018 06:45 - 29 Mar 2018 06:53 #108060
by yrsiddhapura
Intel NUC with mesa 7i76e and some suggestions was created by yrsiddhapura
Hello guys i am new to cnc and linuxcnc and i want to build a cnc machine for my workshop for mechanical side i have completed now all i have to do is electronics and electrical work.
Machine specifications:
I have only three axis Y(linear), Z(linear) and C(circular) and a spindle.
My selection of electronics and electricals.
For pc i have a intel BOXNUC5CPYH 2015 Mini PC with Intel Celeron Processor N3050 2.16GHz, 4gb ram, and 120gb ssd.
And mesa 7i76e
Step-dir servo motor on all axis
And vfd for spindle motor
Query:
-> Does this pc work perfectly with mesa 7i76e and perform well ?
->I want to add an external encoder only for C axis (may be on another axis too but in future not right now) which daughter card(7i76e supported) i will required ?
->Can i config direc C axis with out A and B ?
Thanks in advance
-Yagnesh
And mesa 7i76e
Query:
Thanks in advance
-Yagnesh
Last edit: 29 Mar 2018 06:53 by yrsiddhapura.
- Thank you received: 4130
29 Mar 2018 08:21 - 29 Mar 2018 08:22 #108062
Replied by rodw on topic Intel NUC with mesa 7i76e and some suggestions
At a guess, your PC will probably be OK. I have used N3160 and J1900 USFF PC's with the 7i76e without any dramas. Yours appears to be a similar one in that family. I think you have 2 cores v's 4 cores which should not be a drama
You will need to disable all of the power saving feature in the BIOS and disable or remove the internal Wifi card as they will cause enormous hit on latency. Use a USB wifi dongle instead.
I'm not sure about your C axis in V2.7 but I think it would be fine in master branch V2.8 as it has seperated the joints (motors) from the axes. eg. Axes are no longer hard coded to align with the joints so I think it will be able to be done. Someone else would need to confirm behaviour in V 2.7 as I've never used it.
Last edit: 29 Mar 2018 08:22 by rodw.
The following user(s) said Thank You: yrsiddhapura
- yrsiddhapura
29 Mar 2018 09:23 #108063
by yrsiddhapura
Replied by yrsiddhapura on topic Intel NUC with mesa 7i76e and some suggestions
Thank you rodw
As you said i was also looking forward to use J1900 or N3700 which are quad core processor that's nice tip. And i am also thankful to your help.
And i want to attach an external encoder to my 'C' Axis so which daughter card i will required ? Can you help me with this.
29 Mar 2018 09:26 #108064
Sorry, I have no experience. I am sure PCW will find your question and respond
Thank you rodw
Time to create page: 0.281 seconds
