which mesa card combo should i use?
07 Apr 2018 04:53 #108541 by thang
can someone recommend me some mesa card combo i should use?
I need to control 7 axis by analog signal so system require: 7 analog output channels, 7 uart channels ( i just need 7 RX channels to get serial data), 7 encoder channels.
I have experience in creating new bitfile, using mesa 5i25, 7i74, 7i83
08 Apr 2018 22:33 #108631 by tommylight
Replied by tommylight on topic which mesa card combo should i use?
The 5i25 or 6i25 or 7i92m with two 7i77 will give you 10 analogue outputs, 2 spindle outputs, 12 encoder inputs (even more depending on the mode you set), 64 digital inputs (some can be used as analogue), 32 outputs.
The following user(s) said Thank You: thang
10 Apr 2018 12:55 - 10 Apr 2018 12:55 #108725 by andypugh
Replied by andypugh on topic which mesa card combo should i use?
Maybe the 5i24 + 2x 7i33TA + 7i44
You could add more GPIO by configuring the 7i44 with 7 x UART + 1 x smart-serial.
You could possibly swap the 2x 7i33 for 1 x 7i65 (at higher total cost) to free-up some more IO pins.
The 7i65 uses the BSPI Hostmot2 module, it is possible that that is incompatible with the Mesa UART and / or smart-serial (Check with Mesa to be sure)
I don't know how many people are using the 7i65, but if there are any problems then I do have one for testing purposes so should be able to fix any issues.
Last edit: 10 Apr 2018 12:55 by andypugh.
10 Apr 2018 13:08 #108726 by thang
Replied by thang on topic which mesa card combo should i use?
for simple, i have plan to use x2 5i25 + 7i74 + x27i83. One for smart serial , the other for 7 UART channels and 7 encoder channels
10 Apr 2018 13:31 #108732 by andypugh
1 x 5i24 has more IO pins (72) than 2 x 5i25. (2 x 34 = 68)
I really think that you should take a look at the 50-pin-header boards.
11 Apr 2018 08:01 #108793 by thang
which 5i24 card are you using? 5i24-16 or 5i24-25, actually i dont know what difference between them. My system requires a lot of IOs, how do i load firmware for 5i24 if i have 2-3 5i24 PCI cards in my PC ? And creating new bitfile for this card is same way as 5i25?
11 Apr 2018 08:47 #108797 by thang
seem 5i24 is also reprogram card, so it needs to be flashed by mesaflash
11 Apr 2018 09:55 #108798 by tivoi
Replied by tivoi on topic which mesa card combo should i use?
The MESA 6I68 (shown here with 3X20 installed) is a simple motherboard for 3X2X series FPGA daughtercards that plugs into a standard one lane PCI-Express slot. The 6I68 provides a base and simplified I/O connections for the 3X2X series daughtercards. The 6I68 can be used for evaluation of 3X2X series cards or for final applications. The 6I68 buffers all I/O pins with quickwitches for 5V tolerance on all I/O, and provides jumpers for setting the 3X2X's VIO levels and configuration options. The 7I68 distributes the 3X2X's 144 I/O signals to six 50 pin .1" headers with standard Anything I/O pinouts. All signal are routed as differential pairs, allowing high speed differential signaling if desired.
144io
11 Apr 2018 10:39 #108799 by thang
is this board possible to use with combo 7i33TA and 7i44?Can i use Xilinx ise to creat a custom bitfile for it too?
11 Apr 2018 10:46 #108800 by andypugh
The difference is the size of the FPGA memory.
As far as I can see looking at the available firmwares there are not any standard Hostmot2 firmwares that don't fit into the smaller card.
(But there don't seem to be any precompiled bitfiles for your particular needs)
Moderators: PCW, jmelson
Time to create page: 1.614 seconds
