2.8 pre locks up and wont load
- JR1050
- Thank you received: 31
12 Apr 2018 21:35 #108924
by JR1050
2.8 pre locks up and wont load was created by JR1050
Hello,
I recently upgraded to the latest master 2.8 from a previous 2.8(approx a year old, ver 277, i think) . Lcnc tries to load and locks up withe following error( see pi error attachment for complete log)
HAL: ERROR: pin_new(hm2_7i90.0.led.CR2976) called with already-initialized memory
HAL: ERROR: pin_new(hm2_7i90.0.led.CR2977) called with already-initialized memory
HAL: ERROR: pin_new(hm2_7i90.0.led.CR2978) called with already-initialized memory
HAL: ERROR: pin_new(hm2_7i90.0.led.CR2986) called with already-initialized memory
rtapi_app: caught signal 11 - dumping core
I had this all working actually moving my Hardinge with the rspi .Now Lcnc hang up on with the above error, suggestions??Thanks
- Thank you received: 7504
28 Apr 2018 16:38 #109773
Replied by tommylight on topic 2.8 pre locks up and wont load
Check if you have duplicate entries for those error lines in hal.
You are getting a signal 11, and that most probably means bad memory or failing memory controller.
If you have multiple memory modules installed, remove all but one and try again...........then again i think you are using a RPI, so you can not do that. Do you have any over clocking active? If yes, try it without over clocking or try under clocking the processor and memory.
02 May 2018 16:11 #110054
Replied by andypugh on topic 2.8 pre locks up and wont load
Always the same error? It seems very strange as it knows you only have one led and then tries to create 4 (or possibly thousands)
It is probably worth adding "num_leds=0" to the config string to see if that makes the problem go away.
(If it does then I need to look at the LED driver)
- JR1050
03 May 2018 21:24 #110163
by JR1050
Replied by JR1050 on topic 2.8 pre locks up and wont load
Ok, things that make ya go danm.....In an attempt to make this issue go away, I uninstalled the newer 2.8 and put the latest 2.7, which would hang up loading the driver, I suspect I put the rtai version on instead of the sim.
Anyway..... I reloaded 2.8 this evening and got the same error with the rspi driver, but now the hm2-rspi driver works.Go figure, so...
It is a lathe config and if I try the newer joint/axis asignment like so
[AXIS_Z]
MIN_LIMIT = -10.
MAX_LIMIT = .25
MAX_VELOCITY = 3.3
MAX_ACCELERATION = 10.
## Z axis
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 3.3
ect
I get this
check_config: ERROR
(Using identity kinematics: trivkins)
[JOINT_1]MIN_LIMIT > [AXIS_Y]MIN_LIMIT (-10. > -1e99)
[JOINT_1]MAX_LIMIT < [AXIS_Y]MAX_LIMIT (.25 < 1e99)
check_config validation failed
The config will load with this:
[KINS]
KINEMATICS = trivkins
JOINTS = 3
[TRAJ]
AXES = 3
COORDINATES = X Z
HOME = 0 0 0 0
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 3.3
MAX_VELOCITY = 3.3
DEFAULT_ACCELERATION = 14.0
MAX_ACCELERATION = 14.0
MAX_LINEAR_VELOCITY = 3.3
[AXIS_X]
MIN_LIMIT = -6.0
MAX_LIMIT = .08
MAX_VELOCITY = 3.3
##X axis
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 3.3
BACKLASH = 0.000
INPUT_SCALE = -60000
OUTPUT_SCALE = 1.
OUTPUT_OFFSET = 0
MIN_LIMIT = -6.0
MAX_LIMIT = .08
FERROR = .015
MIN_FERROR = .004
HOME_OFFSET = 0
HOME_SEARCH_VEL = 1.
HOME_LATCH_VEL = -.5
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = no
MAX_OUTPUT = 1.
# PID tuning params
DEADBAND = 0
P = 60.
I = 3.
D = 2.
FF0 = 0
FF1 = .020
FF2 = .02
BIAS = 0
[AXIS_Z]
MIN_LIMIT = -10.
MAX_LIMIT = .25
MAX_VELOCITY = 3.3
## Z axis
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 3.3
BACKLASH = 0.000
OUTPUT_SCALE = 1.000
OUTPUT_OFFSET = 0.0
MIN_LIMIT = -10.
MAX_LIMIT = .25
FERROR = .02
MIN_FERROR = .006
HOME_OFFSET = 0
HOME_SEARCH_VEL = -1.
HOME_LATCH_VEL = .5
MAX_OUTPUT = 1.0
# PID tuning params
DEADBAND = 0
P = 60.
I = .5
D = .8
FF0 = 0
FF1 = .011
FF2 = .0002
BIAS = 0
##spindle
[SPINDLE_1]
MAX_VELOCITY = 50.
MAX_ACCELERATION = 20.0
BACKLASH = 0.000
INPUT_SCALE = 8192
##8192
OUTPUT_SCALE = 1.
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1.0
# PID tuning params
DEADBAND = 0.000015
P = 0
I = 0
D = 0
FF0 = 0.02
FF1 = 0
FF2 = 0
BIAS = 0
##mpg
[JOINT_3]
INPUT_SCALE = 100
MAX_VELOCITY = 3.3
MAX_ACCELERATION = 5.
[EMCIO]
I suspect Im missing something. A couple weeks ago I had an issue with z homing, tell it to home and it sat still and zero's it self, never searches for the limit switch.Thanks
[AXIS_Z]
MIN_LIMIT = -10.
MAX_LIMIT = .25
MAX_VELOCITY = 3.3
## Z axis
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 3.3
ect
I get this
check_config: ERROR
[KINS]
JOINTS = 3
[TRAJ]
AXES = 3
COORDINATES = X Z
HOME = 0 0 0 0
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
MAX_VELOCITY = 3.3
[AXIS_X]
MIN_LIMIT = -6.0
MAX_LIMIT = .08
MAX_VELOCITY = 3.3
##X axis
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 3.3
BACKLASH = 0.000
OUTPUT_SCALE = 1.
OUTPUT_OFFSET = 0
MIN_LIMIT = -6.0
MAX_LIMIT = .08
FERROR = .015
MIN_FERROR = .004
HOME_OFFSET = 0
MAX_OUTPUT = 1.
# PID tuning params
DEADBAND = 0
P = 60.
I = 3.
D = 2.
FF0 = 0
FF1 = .020
FF2 = .02
BIAS = 0
[AXIS_Z]
MIN_LIMIT = -10.
MAX_LIMIT = .25
MAX_VELOCITY = 3.3
## Z axis
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 3.3
BACKLASH = 0.000
OUTPUT_OFFSET = 0.0
MIN_LIMIT = -10.
MAX_LIMIT = .25
FERROR = .02
MIN_FERROR = .006
HOME_OFFSET = 0
HOME_LATCH_VEL = .5
MAX_OUTPUT = 1.0
# PID tuning params
DEADBAND = 0
P = 60.
I = .5
D = .8
FF0 = 0
FF1 = .011
FF2 = .0002
BIAS = 0
##spindle
[SPINDLE_1]
MAX_VELOCITY = 50.
BACKLASH = 0.000
INPUT_SCALE = 8192
##8192
OUTPUT_SCALE = 1.
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1.0
# PID tuning params
DEADBAND = 0.000015
P = 0
I = 0
D = 0
FF0 = 0.02
FF1 = 0
FF2 = 0
BIAS = 0
##mpg
[JOINT_3]
INPUT_SCALE = 100
MAX_VELOCITY = 3.3
[EMCIO]
04 May 2018 04:58 #110189
What is you [KINS] section?
For a lathe you want the final result of HAL and INI to give you "loadrt trivkins coordinates=xz"
The following user(s) said Thank You: JR1050
- JR1050
04 May 2018 22:51 #110230
by JR1050
Got it. The syntax in the ini file has to be exact. That was also the source of the homing problem. The sim may load the old style axis/joint definitions, but it seems to get the axis's to home they have to be in assigned order , meaning if you have a joint for Y , you can't home Z until Y is homed.
- Thank you received: 4154
05 May 2018 02:04 #110237
Thats not correct. The HOME_SEQUENCE in the .ini file determines the order of homing. If you have a joint axis such as a gantry, the sets of joints making up an axes needs to be an identical negative number. The 2.8 homing configuration docs is quite precise about how it all works.
Replied by rodw on topic 2.8 pre locks up and wont load
Time to create page: 0.504 seconds
