PCIe Parallel cards - what chipset?
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
29 Apr 2018 20:20 #109822 by ozzyrob
Replied by ozzyrob on topic PCIe Parallel cards - what chipset?
Ok
Taken from:
www.vdwalle.com/Norte/Second%20Parport.htm
download this script, rename it to ppdiag.sh and run it as: sh ppdiag.sh
www.vdwalle.com/Norte/ppdiag.txt
And lets see what output we have.
29 Apr 2018 20:27 #109823 by cupakm
Replied by cupakm on topic PCIe Parallel cards - what chipset?
S01: parport built as module
S02: parport0:
S02:	modes:PCSPP,TRISTATE,EPP
S02:	ADDR :0xE010
S02:	IRQ  :27
S02:	DMA  :no DMA used
grep: /etc/modules.conf: No such file or directory
S03: no parport parameters
S10: ppdev built as module
S12: /dev/parport0 exists ...
S12: /dev/parport0 is readable ...
S12: /dev/parport0 is writable ...
S12: do you want to allow any user to access ppdev ? (yes/no)
yes
S12: mode changed ...
successfull end ....
29 Apr 2018 20:56 #109831 by tommylight
Replied by tommylight on topic PCIe Parallel cards - what chipset?
Sorry for the late reply.
You can skip everything and just make a new config with stepconf wizard and enter the 0xe000 address instead of 0x387 and test it, if it does not work restart the computer and change that address to 0xe010.
One of them must work.
You can also start linuxcnc directly from the menu and pick the parallel port test config there, edit the hal file replacing the 0x387 or 0x287 with 0xe010 or 0xe000.
27 Jun 2019 19:14 #138018 by Bari
Replied by Bari on topic PCIe Parallel cards - what chipset?
The kernel has been updated to support this chip and board configuration: This driver was added to the kernel for Dev. ID 3050, Date: Sat, 26 May 2018, Kernel 4.14 git.kernel.org/pub/scm/linux/kernel/git/...788f7d57b3b8d1a030ab
Debian also back ported this to earlier kernels since it is working with Kernel 4.9
www.ebay.com/itm/NEW-DB25-25-pin-LPT-Por...Adapter/272174222785 $9.29 shipped, confirmed working with LCNC on newer kernels June 27, 2019
28 Jun 2019 01:29 #138074 by jmelson
Replied by jmelson on topic PCIe Parallel cards - what chipset?
But, LinuxCNC does not use the kernel driver for real time control through the parallel ports. So, as long as the board follows the generic parport register layout, it will work with the various LinuxCNC internal drivers that use the parallel port.
Jon
28 Jun 2019 18:04 #138131 by pl7i92
Replied by pl7i92 on topic PCIe Parallel cards - what chipset?
all modern pci and pcie are now working as the drivers are standards since 2015
so insert a modern 2port pci card to the pc
Start it up (( most people are entering bios and safe the config no entrys needed))
then as OS si running enter
dmesg | grep parpo*
in a terminal
and write down your adresses 0x2022 or simular
parport 0 is the oncard paroprtt 1 is the extra cable port
goto your mashine file folder and open the HAL file named as your mashine
look at
loadrt hal_parport cfg="0x378 out" -> change to 0x2022 or what you reed in terminal
setp parport.0.reset-time 6000
safe and restart linuxcnc
01 Jul 2019 12:09 #138295 by andypugh
Replied by andypugh on topic PCIe Parallel cards - what chipset?
These devices don't behave as a parallel port without the driver loaded, though, if they are the ones I think they are.
They basically have an uncommitted IO chip that becomes a serial port, parallel port (and maybe other things) depending on the firmware that is loaded at startup.
I guess there is intriguing possibility of building a specific, custom CNC firmware for them.
01 Jul 2019 12:30 #138297 by Bari
Here's the drama behind these cards:
wiki.linuxcnc.org/cgi-bin/wiki.pl?WCH
They would not show up in "dmesg | grep parpo" since the kernel would not recognize them until they were added to the kernel driver.
01 Jul 2019 12:39 #138298 by Bari
No firmware required. Use a newer rt kernel, software step away.
Moderators: PCW, jmelson
Time to create page: 0.402 seconds
