custom board for smart serial interface?
25 Apr 2018 01:37 #109579 by incomplete
custom board for smart serial interface? was created by incomplete
i 'm using mesa PCI card with 7i74 break out board. I would like to design a daughter board for read write IO instead of use mesa remote daughter cards. Is there any documents that explain smart serial protocol and source code that i need to design this board? Are these licensed?
25 Apr 2018 05:10 #109585 by rodw
Replied by rodw on topic custom board for smart serial interface?
With the right bit file, the Mesa SmartSerial UART can be exposed.
linuxcnc.org/docs/html/man/man9/hostmot2.9.html#UART
This allows you to read and write to the RS422 interface.
There is a gyroscope example floating around so have a look at that and see if it might do what you want.
Andy is the expert on the UART and maybe PCW will write a bitfile for you ...
25 Apr 2018 09:23 #109594 by PCW
The protocol is described in the back of any Mesa smart serial interface card manual (SSLBP and LBP sections)
You might look at the STMBL project as a code example
The following user(s) said Thank You: tivoi, incomplete, silopolis
26 Apr 2018 07:36 #109646 by andypugh
Replied by andypugh on topic custom board for smart serial interface?
This is handled, in the case of Mesa cards, by an FPGA. The source-code is here:
github.com/LinuxCNC/hostmot2-firmware/bl...ster/src/sserial.vhd
STMBL uses the STM32 microprocessor, so the source-code is in C and might be more easily adaptable:
github.com/rene-dev/stmbl/blob/master/src/comps/sserial.c
The following user(s) said Thank You: silopolis
26 Apr 2018 07:37 #109647 by andypugh
What would be really useful here might be an Arduino smart-serial library.
The following user(s) said Thank You: PKM, incomplete
26 Apr 2018 11:30 #109666 by incomplete
Replied by incomplete on topic custom board for smart serial interface?
I found that source code yesterday, thank you very much.
I read mesa smart serial manual but i dont understand what SSLBP and LBP stand for. It seem SSLBP describe smart serial handled by FPGA card( maybe i can skip this) and LBP handled by peripherals like 7i69,7i83...
I dont really get it. Do you mean Arduino also have this protocol library?
26 Apr 2018 11:41 #109669 by PCW
SSLBP is a specific Smart Serial FPGA module for interfacing with remote devices using the LBP protocol.
LBP remotes implement the LBP protocol
(For example a Modbus Smart Serial interface would be possible using the same smart serial FPGA firmware but a different
software ROM: SSModbus)
26 Apr 2018 11:55 - 26 Apr 2018 11:56 #109671 by andypugh
I think it is "Smart Serial Little Binary Protocol" and "Little Binary Protocol"
No, I mean that it would be really useful if someone could write it :-)
Last edit: 26 Apr 2018 11:56 by andypugh.
27 Apr 2018 07:22 #109701 by fupeama
Replied by fupeama on topic custom board for smart serial interface?
can arduino run on the 2.5Mbit/s on uart??
STM32 (cortex) or PIC is better choice I think.
Martin
27 Apr 2018 08:08 #109705 by andypugh
It can at a 20MHz clock, but it looks like the answer is "no" otherwise, even at 84MHz
wormfood.net/avrbaudcalc.php?bitrate=500...C48%2C+84&databits=8
Moderators: PCW, jmelson
Time to create page: 0.180 seconds
