Parallel port onboard vs card?
14 May 2018 14:52 #110729 by diodeut
Parallel port onboard vs card? was created by diodeut
Hello All,
Sorry if this has been asked I have been reading several notes and don't seem to see it.
So I have been running Linuxcnc for about 4 years with no issue until my computer decided to die. Long story short. The new MB has a parallel port where the old one did not. ( I was using a parallel card)
Is there any benefit to using the onboard port vs the card that I should be looking at? I got thinking about this when I was re-configuring the address for the card on the new MB.
Thanks in advance
14 May 2018 15:26 #110730 by PCW
Replied by PCW on topic Parallel port onboard vs card?
Heres a couple of things
On-board port advantages:
No extra card to buy
EPP mode works
Known address
No driver issues
Plug in parallel port card advantages:
Easy to replace if damaged
PCI/PCIE cards have faster access time than on board (LPC bus) ports
The following user(s) said Thank You: Tchefter, diodeut, irakandjii
Moderators: PCWjmelson
Time to create page: 0.134 seconds
