sserial error
17 May 2018 11:03 - 17 May 2018 11:03 #110813 by thang
sserial error was created by thang
When i run linuxcnc via halcmd to test sserial with commands:
File Name: sserial_halcmd.txt
File Size:0 KB
i get the error:
File Name: sserial_error.txt
File Size:3 KB
But when i creat ini and hal file to run, it works, any idea why this error happens? One thing i see difference here is name of period.
File Name: 5i25_dorna...5-17.hal
File Size:2 KB
File Name: 5i25_dorna...5-17.ini
File Size:5 KB
Last edit: 17 May 2018 11:03 by thang.
18 May 2018 22:01 #110858 by andypugh
Replied by andypugh on topic sserial error
What happens if you switch the order of read and write in the test hal?
Typically the cycle is read-calculate-write.
The following user(s) said Thank You: thang
19 May 2018 02:08 #110870 by thang
Replied by thang on topic sserial error
It worked, thank you very much
Moderators: PCWjmelson
Time to create page: 0.375 seconds
