Mesa 7i96 Inputs
03 Jun 2018 15:51 #111513 by thadwald
Mesa 7i96 Inputs was created by thadwald
Can anyone tell me if the following is the correct way to address the input pins on the Mesa 7i96 boards:
input zero:
hm2_7i96.0.gpio.000.in
input one:
hm2_7i96.0.gpio.001.in
The board has only 0-11 broken out on terminal blocks, but in HALShow, I can see up to 050
03 Jun 2018 16:10 #111516 by PCW
Replied by PCW on topic Mesa 7i96 Inputs
Yes, standard firmware maps GPIO 0..10 to 7I96 TB3 inputs 0..10
03 Jun 2018 17:12 #111527 by thadwald
Replied by thadwald on topic Mesa 7i96 Inputs
Thanks!
Are gpio 11 to 50 broken out on the board?
03 Jun 2018 17:37 #111529 by PCW
With HM2 firmware, all I/O pins have GPIO capability so even pins normally used for things like stepgenerators can be used as GPIO, so the GPIO 0..50 represent all I/O pins including the expansion connector I/O. If you run mesaflash with the readhmid option you can get a listing of the I/O mapping.
03 Jun 2018 17:39 #111530 by thadwald
That is exactly what I was looking for. Thanks!
03 Jun 2018 18:17 #111532 by PCW
I should mention that this needs to be the latest version of mesaflash that "knows" about the 7I96 pinout
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 2 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
14      1   IOPort       None
 2      2   IOPort       None
15      3   IOPort       None
 3      4   IOPort       None
16      5   IOPort       None
 4      6   IOPort       None
17      7   IOPort       None
 5      8   IOPort       None
 6      9   IOPort       None
 7     10   IOPort       None
 8     11   IOPort       SSR              0        Out-00          (Out)
 9     12   IOPort       SSR              0        Out-01          (Out)
10     13   IOPort       SSR              0        Out-02          (Out)
11     14   IOPort       SSR              0        Out-03          (Out)
12     15   IOPort       SSR              0        Out-04          (Out)
13     16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2
 1     17   IOPort       StepGen          0        Step/Table1     (Out)
14     18   IOPort       StepGen          0        Dir/Table2      (Out)
 2     19   IOPort       StepGen          1        Step/Table1     (Out)
15     20   IOPort       StepGen          1        Dir/Table2      (Out)
 3     21   IOPort       StepGen          2        Step/Table1     (Out)
16     22   IOPort       StepGen          2        Dir/Table2      (Out)
 4     23   IOPort       StepGen          3        Step/Table1     (Out)
17     24   IOPort       StepGen          3        Dir/Table2      (Out)
 5     25   IOPort       StepGen          4        Step/Table1     (Out)
 6     26   IOPort       StepGen          4        Dir/Table2      (Out)
 7     27   IOPort       QCount           0        Quad-A          (In)
 8     28   IOPort       QCount           0        Quad-B          (In)
 9     29   IOPort       QCount           0        Quad-IDX        (In)
10     30   IOPort       SSerial          0        RXData0         (In)
11     31   IOPort       SSerial          0        TXData0         (Out)
12     32   IOPort       SSerial          0        TXEn0           (Out)
13     33   IOPort       SSR              0        AC Ref          (Out)
IO Connections for P1
 1     34   IOPort       SSerial          0        RXData1         (In)
14     35   IOPort       SSerial          0        RXData2         (In)
 2     36   IOPort       None
15     37   IOPort       None
 3     38   IOPort       SSerial          0        TXData1         (Out)
16     39   IOPort       SSerial          0        TXData2         (Out)
 4     40   IOPort       None
17     41   IOPort       None
 5     42   IOPort       SSerial          1        RXData0         (In)
 6     43   IOPort       SSerial          1        RXData1         (In)
 7     44   IOPort       None
 8     45   IOPort       None
 9     46   IOPort       SSerial          1        TXData0         (Out)
10     47   IOPort       SSerial          1        TXData1         (Out)
11     48   IOPort       None
12     49   IOPort       None
13     50   IOPort       None
Moderators: PCW, jmelson
Time to create page: 0.107 seconds
