Mesa 7i76 spindle wiring to a Leeson Speed Master VFD
10 Jun 2018 02:02 - 10 Jun 2018 19:50 #112115 by buffcleb
I'm converting a CNC Masters Baron Mill... I have the steppers wired but am confused on how to wire the spindle to the 7i76 board...
With the CNC Master's control board it used the first six pins.. Here's the wiring diagram from the manual
Any help wiring the tb4 pins to the VFD would be a huge help...
thanks
Last edit: 10 Jun 2018 19:50 by buffcleb.
10 Jun 2018 17:52 - 10 Jun 2018 18:34 #112141 by buffcleb
ok... I tried this wiring :
Tb4 - leeson
1 - 2
6 - 1
3 - 5
2 - 11
7 - 13a
If I enable the spindle in LinuxCNC I get nothing... so I tried jumping pins 1 to 11 on the leeson and I get forward motion... If I jumper 1, 11 and 13a I get reverse... now I need to figure out what to do next... not sure how to configure LinuxCNC to do this...
Last edit: 10 Jun 2018 18:34 by buffcleb.
10 Jun 2018 18:35 #112143 by buffcleb
Figured I should share my Hal file... it's stock... I've not made any changes... I can see the voltage change on the VFD between pins 2 and 5...
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp hm2_5i25.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-output => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable => hm2_5i25.0.7i76.0.0.spinena
net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
10 Jun 2018 20:30 - 10 Jun 2018 20:34 #112148 by PCW
I would wire it like this:
7I76      LEESON     FUNCTION
TB4.1     2          ANALOG COMMON-
TB4.2     5          ANALOG SPEED CONTROL VOLTAGE
TB4.3     6          ANALOG VOLTAGE SUPPLY (+10V)
TB4.5     1          SPINDLE ENABLE - (RUN)
TB4.6    11          SPINDLE ENABLE +
Note that unless you can program the VFDs pin 13 to be a direction pin rather than "run reverse",
an external relay may be needed to get bidirectional control.
Also I am assuming that the digital input reference is a positive voltage. if its ground and the run input is a positive voltage you will have to reverse TB4 pins 5 and 6
Last edit: 10 Jun 2018 20:34 by PCW.
The following user(s) said Thank You: buffcleb
10 Jun 2018 20:38 #112150 by ReneCNC
Hi buffcleb,
I also use a 7i76 on my machine, but i have a different VFD.
The spindle enable and direction on the 7i76 are open-collector outputs,
not sure but i think you have to connect TB4 Pin 5 and6 to VFD pin 1 and 11,
and for reverse TB4 7 and 8 to VFD 13a and 11
11 Jun 2018 01:52 #112167 by buffcleb
This worked... thank you... tested it to full rpm and verified it with one of those laser meters... Here are the programable functions on the VFD...
None of those seem to be a direction... so I'm going to have to figure something out...
11 Jun 2018 13:52 #112191 by PCW
Do you have a link to a PDF version of the manual?
11 Jun 2018 14:13 #112192 by buffcleb
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Online
  • Platinum Member
  • Platinum Member
11 Jun 2018 17:25 #112203 by Todd Zuercher
Replied by Todd Zuercher on topic 7i76 spindle wiring to a Leeson Speed Master VFD
Those look just like the Lenze AC-tech drives I have on a couple machines. (I'm using Modbus to control those.)
11 Jun 2018 18:57 #112213 by buffcleb
yeah I would say the Lenze AC-tech SCM series are the same as the Leeson Speed Master VFD's... I don't see anything in the PDF about Modbus... I'll hunt around as see what I can find... maybe there's another manual about it...
Moderators: PCW, jmelson
Time to create page: 0.603 seconds
