Mesa 7i96 driver/setup Plasma Table
- snugglylovemuffin
- Thank you received: 11
01 Jul 2018 15:46 #113170
by snugglylovemuffin
Mesa 7i96 driver/setup Plasma Table was created by snugglylovemuffin
Built an XXYZ Plasma table, having trouble with a few things. I'm entirely new to Linuxcnc is the first problem, the second problem is that I'm using a card that is relatively new, and information is relatively scarce. I've updated my version to 2.8 (master) and Mesa says "there is no firmware specifically for the 7i96 and that the 2.8 version already has the drivers for the card integrated into the hostmot2 and hm2_eth drivers.
A: Since there is no specific driver for the 7i96 when selecting board+firmware, which leaves me with selecting a host of options that may, or may not, work. I've found a potential solution, but I'm unaware of how to actually implement it, and is ostensibly entirely redundant... according to Mesa. The closest numerical option for the board is "7i92" and firmware options are only for that of the 7i76/7i77
github.com/LinuxCNC/linuxcnc/blob/master...s/man/man9/hm2_eth.9
B: Network configuration issues - forum.linuxcnc.org/27-driver-boards/3276...ernet-board?start=10
working on solution on pages 3-4
C: I'm probably thinking too far ahead, however, how then do I install my Proma THC? My concern is the lack of support for input/output without the proper firmware.
- Thank you received: 5326
01 Jul 2018 16:12 #113173
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
Firmware is the "code" on the FPGA, there is no need to change this.
The hm2_eth driver in LinuxCNC 2.8 full supports the 7I96
There is no pncconf (setup utility) support for the 7I96 yet so you either need to create a hal/ini file set by editing one of the example files or the 7I96 example here:
freeby.mesanet.com/7i96-2.8.zip
- snugglylovemuffin
01 Jul 2018 17:14 #113177
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
Absolutely fantastic, thank you very much. I will begin working on this post haste.
- Thank you received: 2181
01 Jul 2018 20:22 #113182
Replied by cmorley on topic Mesa 7i96 driver/setup Plasma Table
I was going to ask you to try pncconf's experimental discovery option, but then remembered mesaflash is not included with linuxcnc and is a bit of a hassle to add.
I think we should add that to linuxcnc...
Chris M
Chris M
The following user(s) said Thank You: snugglylovemuffin
01 Jul 2018 20:43 #113183
I think so too, but AFAIK you can just:
sudo apt-get install mesaflash
to install it on a standard LinuxCNC system (that has the repositories setup)
- snugglylovemuffin
01 Jul 2018 21:49 #113188
I am but a new fish in a large pond. If I can do it without risk of bricking my card, I may be willing to try it with a backup and some good instructions.
01 Jul 2018 21:57 - 01 Jul 2018 21:58 #113190
While you definitely _can_ brick your card with mesaflash by writing incorrect firmware to the card,
what mesaflash is used for here is simply reading out the cards configuration information.
Last edit: 01 Jul 2018 21:58 by PCW.
- Thank you received: 7481
01 Jul 2018 22:08 #113193
What type of Proma THC ? Is it the 150 version or the "SD" version?
In any case editing a few things in the hal and ini files should get you going.
Replied by tommylight on topic Mesa 7i96 driver/setup Plasma Table
- snugglylovemuffin
01 Jul 2018 22:51 #113197
It's the Proma 150 THC. Currently learning how to edit HAL files. Such an adventure!
- snugglylovemuffin
07 Jul 2018 20:38 #113715
I seem to be encountering a networking issue, the computer recognizes the card as a wired network, however I'm not getting any motion. Do I need to manually configure the network properties for the card? The manual isn't much help in this regard.
I've pinned it out to the default EEPROM 10.10.10.10
Time to create page: 1.171 seconds
