Mesa 7i96 driver/setup Plasma Table
  • snugglylovemuffin
  • snugglylovemuffin's Avatar Topic Author
  • Elite Member
  • Elite Member
15 Jul 2018 23:49 - 15 Jul 2018 23:50 #114251 by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
As far as I can tell, Preempt-RT is completely enabled (error still says "Note: POSIX real time", no clue why); I did however discover that Stretch departs from eth(0/1) and instead uses, in my case, enp5s0 (enp6s0, enp8s0, enp0s31f6).
Could this be affecting the hm2_eth module in linuxcnc? I may be showing my ignorance here, I just can't for the life of me figure out why this is still an issue.
Last edit: 15 Jul 2018 23:50 by snugglylovemuffin.
16 Jul 2018 00:55 #114254 by PCW
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
You had this before (which means no real time Preempt-RT kernel:
Note: Using POSIX non-realtime
Now you have this:
Note: Using POSIX realtime
This is correct
I suspect the "Connection refused" issue is something wrong with your network setup
what is the result of running the command:
ip a
on your machine?
  • snugglylovemuffin
  • Elite Member
  • Elite Member
16 Jul 2018 01:57 #114257 by snugglylovemuffin
Damn... how is this possible; what else do I need to do?
~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 1c:6f:65:cd:65:12 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.30/24 brd 192.168.0.255 scope global dynamic enp5s0
valid_lft 66722sec preferred_lft 66722sec
inet6 fe80::b59e:571b:1798:c3ad/64 scope link
16 Jul 2018 02:05 - 16 Jul 2018 02:06 #114258 by PCW
OK so it looks like your only Ethernet hardware is setup for the wrong address
Did you read the hm2_eth manual page about setting up a static IP address on the host?
Suggested host address is 10.10.10.1 if the 7I92 is setup for 10.10.10.10
Last edit: 16 Jul 2018 02:06 by PCW.
  • snugglylovemuffin
  • Elite Member
  • Elite Member
17 Jul 2018 16:33 - 17 Jul 2018 16:36 #114404 by snugglylovemuffin
haha I was just reading though them in order to make sure I wasn't missing anything. Pardon my ignorance. I'm going through the process now and I'm having a problem changing permissions in the network folder of the file system.
linuxcnc.org/docs/html/man/man9/hm2_eth.9.html
I was unable to add the script to the "setup" document in the "interfaces.d" (I'm assuming that's the document I need to modify, contextually it has an eth0 script)
I attempted to change permissions by using: chmod +rwx "interfaces-d", I was however denied permission.
the address will be changed 10.10.10.10
Last edit: 17 Jul 2018 16:36 by snugglylovemuffin.
17 Jul 2018 16:54 #114407 by PCW
Please dont change the permissions/modes of any system file
The instructions in the hm2_eth manual page state
Configure network with static address
Add these lines to the file /etc/network/interfaces to configure eth1
with a static address:
auto eth1
iface eth1 inet static
address 192.168.1.1
hardware-irq-coalesce-rx-usecs 0
You will have to change the ip address in the file to say 10.10.10.1 and probably change the device name, Also the "hardware-irq-coalesce-rx-usecs 0" is typically only appropriate for Intel MACs
to edit the interfaces file you use sudo:
sudo mousepad /etc/network/interfaces
You can also avoid all this and use the network manager to setup the MAC
The following user(s) said Thank You: snugglylovemuffin
  • snugglylovemuffin
  • Elite Member
  • Elite Member
17 Jul 2018 20:31 #114414 by snugglylovemuffin
Starting to get really frustrated... I'm getting the exact same error despite all of these efforts. I added the script to "interfaces" and made sure to change the address.
Will "hardware-irq-coalesce-rx-usecs 0" hurt if it's not an intel network card?
Still says "posix realtime"...
  • Moderator
  • Moderator
17 Jul 2018 22:25 - 17 Jul 2018 22:28 #114428 by tommylight
Replied by tommylight on topic Mesa 7i96 driver/setup Plasma Table
As mentioned by PCW earlier, it should say that, it should be "posix realtime". That is the only way Linuxcnc will be able to control hardware. Non-realtime is for simulation and testing only.
BTW, start with a fresh installation, changing system file permissions is not good in any way shape or form.
Last edit: 17 Jul 2018 22:28 by tommylight. Reason: more info
  • snugglylovemuffin
  • Elite Member
  • Elite Member
17 Jul 2018 22:30 #114429 by snugglylovemuffin
Ah okay, I thought it was supposed to say "preept-rt"
Good idea: I botched my dual boot anyway lol.
17 Jul 2018 22:50 #114433 by PCW
"posix realtime" is correct
"hardware-irq-coalesce-rx-usecs 0" will probably just cause an error with a Realtek MAC so really only for Intel and some Broadcom chips
what does ip a report now?
Moderators: PCW, jmelson
Time to create page: 0.174 seconds
