Can 7i76e perform a Wake on LAN to my NUC?
- tecno
- Thank you received: 127
02 Jul 2018 13:10 #113223
by tecno
Can 7i76e perform a Wake on LAN to my NUC? was created by tecno
As in subject, is this possible?
Need to fix a way to start the PC as it is inside a control cabinet. Earlier PC I soldered wires to the start switch but this NUC5PPYH is like Fort Nox = can not find a way to lift out the motherboard.
Same with the BRIX but there I managed to solder cables to start switch.
- Thank you received: 5325
02 Jul 2018 13:55 - 02 Jul 2018 13:57 #113228
Replied by PCW on topic Can 7i76e perform a Wake on LAN to my NUC?
I suppose its possible but would require:
1. The 7I76E have a EEPROM copy of the hosts MAC address (7I76E and Mesaflash changes)
2. The 7I76E have a WOL mode (Does it just do this once at power up?)
Does your NUC support WOL via WIFI? , that might be a lot easier...
Last edit: 02 Jul 2018 13:57 by PCW.
- tecno
02 Jul 2018 14:31 #113230
by tecno
Replied by tecno on topic Can 7i76e perform a Wake on LAN to my NUC?
Did a search for WOL on that type of NUC and it seems not to be the case.
I will go to do this manually, just open the door to the cabinet at the same time I switch on the main power to the lathe, no big issue just convenient to have remote start.
02 Jul 2018 14:47 #113234
What don't you setup the PC BIOS start at power up and just switch the PC's power?
- tecno
02 Jul 2018 14:49 #113235
by tecno
If that can be done, will have a look at that, thanks for the tip.
- Thank you received: 4654
03 Jul 2018 14:32 #113321
Does anything? I suppose it is possible with an integrated adaptor, but I imagine impossible with a USB dongle.
Replied by andypugh on topic Can 7i76e perform a Wake on LAN to my NUC?
03 Jul 2018 14:36 #113322
I have my mill set up like this, with a twist...
There is a mains-power input relay. This has a 5V coil connected to motherboard 5V (USB header I think)
There is a front-panel switch that bypasses the relay.
Press the button, 240V is applied to the system. A second later the 5V on the PC comes up and the relay closes. I can now release the button.
When the PC is closed down it turns off the 5V, and that releases the relay. powering down the whole machine.
- tecno
03 Jul 2018 18:14 #113337
by tecno
- yrsiddhapura
29 Sep 2018 08:20 #118170
by yrsiddhapura
Replied by yrsiddhapura on topic Can 7i76e perform a Wake on LAN to my NUC?
It may help you.
www.intel.in/content/www/in/en/support/a...007309/mini-pcs.html
That's what i had plane for my project. To wire up external power switch to Intel NUC and use NO element and connected it to CNC ON push button.
- Thank you received: 4149
29 Sep 2018 10:55 #118172
Replied by rodw on topic Can 7i76e perform a Wake on LAN to my NUC?
Takes me back to when I modified a laptop to operate as a Car PC years ago. I pulled the machine apart and soldered wires from the power switch on the motherboard to the RJ12 modem port so I could add an external switch. The specialist vehicle PC power supply had a Opto isolator that turned the PC following a delay after the ignition was turned on. You just had to be careful about switch polarity to keep the opto happy. I also added an external momentary switch for manual operation.
So if you can solder in the wires as suggested, there are many ways to trigger a momentary button press. My power supply used an Atmel Mega chip the same as an Arduino.
Time to create page: 0.650 seconds
