5i20 & 7i33 puzzle
8 years 3 months ago #113885 by whizzo944
5i20 & 7i33 puzzle was created by whizzo944
Hello All,
I'm having a head-scratching moment here. I have a 5i20 & 7i33 connected to a chinese analog servo drive & motor.
I have used PnCconfig to write a .ini file using tkemc. If I set position display to actual and turn the motor, the display counts up
& down OK. I have set the following error values to 100mm If I enable the servo, I can jog back & forward, but, if I open hal meter
and display the following error, the error just goes up or down but doesn't return to zero when I stop jogging. If I jog for more than 100mm
then it faults out with following error. It seems to me as if the servo loop isn't closed somehow, but I can jog, so it sort of says the
servo loop is working. Anyone?
TIA,
Dave Winter.
8 years 3 months ago #113892 by cmorley
Replied by cmorley on topic 5i20 & 7i33 puzzle
What version of linuxcnc are you using?
Can you post your INI and HAL file (or the whole config file)
You don't mention encoder feedback but does it count up and down too?
Chris M
The following user(s) said Thank You: whizzo944
8 years 3 months ago #113928 by tommylight
Replied by tommylight on topic 5i20 & 7i33 puzzle
8 years 3 months ago #113932 by whizzo944
Replied by whizzo944 on topic 5i20 & 7i33 puzzle
Hello,
I thought that I was using 2.7.14 but the splash screen when it starts up says 2.7.0 The servo motor & drive are 3 phase
brushless, the encoder is built into the rear of the motor, as is usual these days. On the 5i20 board there are 2 red LEDs which are
on when I start the PC and go out when I start up LCNC. There is something stirring in the back of my mind which thinks there should
be a green LED on on the 5i20 when LCNC is up & running, but there isn't ? Attached is my config folder ( are they folders or
directories in Linux? )
Thanks again,
Dave.
File Name: AMA45.zip
File Size:6 KB
8 years 3 months ago #113938 by PCW
Replied by PCW on topic 5i20 & 7i33 puzzle
If you remove the:
setp pid.x.maxerror .0005
setp pid.y.maxerror .0005
setp pid.z.maxerror .0005
setp pid.s.maxerror .0005
Statements from the hal file, things should work better.
8 years 3 months ago #113949 by whizzo944
Hello Peter,
Looks like that did the trick. I also found lots of settings in my servo drives that needed changing, accel & decel ramps were set to S-shaped, need to be linear and as fast as possible, let LCNC handle the axis ramping. One thing I did find that surprised me was I have all the gains except P set to zero. The drives have an integrator in the speed & torque loops, and if you set any I gain in LCNC
it completely messes things up. I might be able to use FF0 gain to reduce the steady state following error.
Thanks for your help,
Dave.
Moderators: PCW, jmelson
Time to create page: 1.019 seconds
