Mesa 5i25 & 7i77: connecting encoder + one servo motor
7 years 9 months ago #123408 by Todd Zuercher
I have heard of such things. The encoder inputs on the 7i77 are muxed, so that they need half as many input pins on the FPGA. If the 7i77 encoder input is damaged you can get this result. Can you try connecting the Z-axis encoder to another encoder input on the 7i77 (just swap the plug) if you have an unused one. A problem with the mux signal between the 7i77 and 5i25 can cause this and Peter also mention a grounding problem with the encoder on another thread. So check your wiring, reseat the plugs and parallel cable, and see if things are better.
The following user(s) said Thank You: Marki123
7 years 9 months ago #123486 by Marki123
Hi Todd, thanks for the information. I will change the cables and try to try it
7 years 9 months ago #123487 by Marki123
I would like to test the spindle in with the 7i77. Can someone tell me how to wire the spindle to the 7i77. I'm not sure about the pinouts. Unfortunately, I can not read the plans like this
Moderators: PCW, jmelson
Time to create page: 0.318 seconds
