Mesa Suppliers
3 years 3 months ago #274915 by tommylight
Replied by tommylight on topic Mesa Suppliers
To Filipe and Peter:
What is the status 7i97, 7i95, 7i77, 7i96S, 7i92TM?
For now, i need a 7i97 or 7i92/7i77, but i can mix and match from the above.
Preferably in Portugal as this will be ordered through a company in Austria, same company/owner already ordered twice from eusurplus.
I would really hate to yank out mine from the Mazak, but would submit if there is 7i77D in the mix! :)
Would make the wiring neater in the Mazak as i had to make inverters for every output on 7i77 and 7i84.
Thank you.
The only Mesa stuff not used yet is a 6i25 and a 7i73, i am used to having a full suitcase. :(
3 years 3 months ago #274917 by PCW
Replied by PCW on topic Mesa Suppliers
Filipe should have 7I96S + 7I95T + 7I92TM later this month
We should have 7I97T protos (7I97 replacement) soon
7I77s will be a while as they require re-design
An interim solution for Analog drives is a 7I95T and a 7I83,
7I96S+7I89+7I83 or the 7I97T proto
The 7I77 replacement (7I77U) like the 7I76EU can do sinking or sourcing outputs
under software control
3 years 3 months ago #274920 by tommylight
Sorry, he does still have a low amount of 7i92TM, but not the rest.
OK, so leaving this for later, maybe.
The thing is, they lost the 7i77.
They have 2 machines (Elumatec and Hurco), both use 7i92 or 5i25 with 7i77 and 7i74 and 7i70 and 7i71, but someone took 7i92 form Hurco a while back and now they lost 7i77, the rest is there. Hurco was not used waiting for a big a$$ VFD and Elumatec is in daily use. They also have a plasma with 7i76E and THCAD in daily use.
Hmmm how come i did not know about 7i83??? That can also be used through a 7i74 or 7i96S or ....
Oh how niceeeee, no more soldering mess for me! :)
Welectron in Germany seems to have over 10 of 7i96S
www.welectron.com/Mesa-Electronics-7i96S...-Ethernet-Controller
Question, does adding a 7i85 or 7i85S to 7i96S do encoders? I always mix those as i never used the 7i85/S and still not sure what it can do, despite reading several times, i keep messing those up. I think i read here that one of those can be used for encoders, so do not shoot if i am wrong! :)
Thank you for everything, especially for the awesome support.
3 years 3 months ago #274923 by tommylight
Thinking out loud, how viable is :
ethernet
3 step/dir
3 encoders
at least 2 of smart serial
a single IDC26 header, or not
some IO
no spindle
Probably not much as it will need the FPGA, but maybe, just maybe something smaller with more availability?
My brain is mush from looking at cheap servo drives/motors and their less than ideal info, but seems the trend is always have the step/dir inputs.
Also, plenty of lathe retrofits around here, so total of 3 needed, plenty of mills use modbus/RS485 for spindle control so again 3 total.
3 years 3 months ago #274924 by spumco
Replied by spumco on topic Mesa Suppliers
Tommy,
I've got a 7i96s + 7i85s +7i84d + 7i73 in my current project
7i96s => sserial => 7i84d
7i85s => sserial => 7i73
Gives me
  • 9 S&D outputs
  • 5 hs encoder inputs (1 on 7i96s, 4 on 7i85s)
    • spindle, sub-spindle, live-tool, plus X & Z scales!
  • 1 analog spindle output
  • ~60 inputs (using 4x8 matrix keypad on 7i73)
    • 4 0-36v analog inputs
    • 4 0-3.3v analog inputs
    • 6 (!) MPG encoder inputs
  • ~40 outputs
  • 32 button inputs on matrix keypad
Packaging is very easy - the 7i96s and 7i85s are small and can stack if you're clever, and both the 7i84d and 7i73 can be mounted remote from the main enclosure with a simple cat5/6 cable and field power wires (i.e. use a separate box for the field IO closer to wherever your stuff is located on the machine).
This is a stupid amount of capability and IO for four comparatively low-cost boards.
3 years 3 months ago #274983 by tommylight
Sooooo a 7i92 with 7i85S and 7i74, then anything sserial like 7i83 and the existing 7i70 and 7i71 should work just fine.
Leme see if i can order 7i92TM and 7i85S and 7i83, the rest i have, and i have drives that can do analog or SD, so more room for [strike]playing[/strike] hmmm testing.
Ok,
www.welectron.com/Motion-Controller
has 7i96S and 7i72
while
www.eusurplus.com
has 7i92TM, 7i83, 7i85S, 7i72,
Notice 7i72, those are for my Mazak so i can get rid of those hideous output inverters i had to make! :)
@Andy,
Looks like cncmonster.de has become cncmonster.eu and do software stuff, nothing about Mesa that i can find and the link as is does not work.
Might add the welectron link as they are also in Germany.
@Peter,
Feel free to bite my head off if i messed up something, besides having to enrich my Mesa stash, i had to sift through to much stuff last two days as i am thinking of also getting some china servo drives and motors to [strike]playing[/strike] hmmm test and a big VFD! :)
Moderators: PCW, jmelson
Time to create page: 0.177 seconds
