Install the Latest Mesaflash
- BigJohnT
- Thank you received: 994
08 Aug 2018 13:35 - 08 Aug 2018 14:35 #115807
by BigJohnT
Install the Latest Mesaflash was created by BigJohnT
I've downloaded the latest version of mesaflash and followed the two instructions to build mesaflash.
I'm drawing a blank on how to install it on this PC (Linux Mint).
Edit: I tried to build a deb so I could install that but get and error
These are the files in debian
JT
sudo apt-get install libpci-dev
makeI'm drawing a blank on how to install it on this PC (Linux Mint).
dpkg-deb --build mesaflash
dpkg-deb: error: failed to open package info file `mesaflash/DEBIAN/control' for reading: Not a directoryThese are the files in debian
changelog compat control copyright rules source watchJT
Last edit: 08 Aug 2018 14:35 by BigJohnT.
- Thank you received: 5325
08 Aug 2018 15:03 #115812
Replied by PCW on topic Install the Latest Mesaflash
Since mesaflash is just a single small executable with no support files there's not much of a downside to just installing it:
(sudo make install)
(sudo make install)
The following user(s) said Thank You: BigJohnT
- BigJohnT
08 Aug 2018 15:35 #115816
by BigJohnT
Replied by BigJohnT on topic Install the Latest Mesaflash
Peter thanks, I uninstalled the version I had then did the sudo make install.
I wish the readme.md had that bit of information...
JT
JT
