5i25 and 7i77 Do I need to reflash?
8 years 1 month ago #117225 by cncnoob1979
Hey guys! I started my machine after a long hiatus and for the life of me I can figure out what I was messing with when I last shut it down.
But I think i have a firmware issue. I am not getting a blinking light on the 7i77 and field power and 5v seems to be there.
sudo mesaflash --device 5i25 --readhmid >pinout.txt
Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA5I25 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 2 Width of one I/O port: 17 Clock Low frequency: 33.3333 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 2 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCount There are 12 of MuxedQCount in configuration Version: 3 Registers: 5 BaseAddress: 3600 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCountSel There are 1 of MuxedQCountSel in configuration Version: 0 Registers: 0 BaseAddress: 0000 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5B00 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 33.333 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P3 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort SSerial 0 TXEn3 (Out) 14 1 IOPort SSerial 0 TXData3 (Out) 2 2 IOPort SSerial 0 RXData3 (In) 15 3 IOPort SSerial 0 TXData2 (Out) 3 4 IOPort SSerial 0 RXData2 (In) 16 5 IOPort SSerial 0 TXData1 (Out) 4 6 IOPort SSerial 0 RXData1 (In) 17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out) 5 8 IOPort MuxedQCount 0 MuxQ-A (In) 6 9 IOPort MuxedQCount 0 MuxQ-B (In) 7 10 IOPort MuxedQCount 0 MuxQ-IDX (In) 8 11 IOPort MuxedQCount 1 MuxQ-A (In) 9 12 IOPort MuxedQCount 1 MuxQ-B (In) 10 13 IOPort MuxedQCount 1 MuxQ-IDX (In) 11 14 IOPort MuxedQCount 2 MuxQ-A (In) 12 15 IOPort MuxedQCount 2 MuxQ-B (In) 13 16 IOPort MuxedQCount 2 MuxQ-IDX (In) IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort SSerial 0 TXEn6 (Out) 14 18 IOPort SSerial 0 TXData6 (Out) 2 19 IOPort SSerial 0 RXData6 (In) 15 20 IOPort SSerial 0 TXData5 (Out) 3 21 IOPort SSerial 0 RXData5 (In) 16 22 IOPort SSerial 0 TXData4 (Out) 4 23 IOPort SSerial 0 RXData4 (In) 17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out) 5 25 IOPort MuxedQCount 3 MuxQ-A (In) 6 26 IOPort MuxedQCount 3 MuxQ-B (In) 7 27 IOPort MuxedQCount 3 MuxQ-IDX (In) 8 28 IOPort MuxedQCount 4 MuxQ-A (In) 9 29 IOPort MuxedQCount 4 MuxQ-B (In) 10 30 IOPort MuxedQCount 4 MuxQ-IDX (In) 11 31 IOPort MuxedQCount 5 MuxQ-A (In) 12 32 IOPort MuxedQCount 5 MuxQ-B (In) 13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
The culprit is the
hm2_5i25.0: initialized AnyIO board at 0000:04:01.0 ./bridgeport.hal:106: Pin 'hm2_5i25.0.7i77.0.0.output-00' does not exist
So I assume while I was messing with PP2 I must have gotten flashed while I thought I was being careful...
any help greatly appreciated...
bridgeport@bridgeport-H81M-S2PH ~ $ linuxcnc LINUXCNC - 2.8.0~pre1 pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM Machine configuration directory is '/home/bridgeport/linuxcnc/configs/axis_test' Machine configuration file is 'bridgeport.ini' Starting LinuxCNC... Found file(REL): ./bridgeport.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 hm2_pci: discovered 5i25 at 0000:04:01.0 hm2/hm2_5i25.0: Smart Serial Firmware Version 43 Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables hm2/hm2_5i25.0: 34 I/O Pins used: hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:04:01.0 ./bridgeport.hal:106: Pin 'hm2_5i25.0.7i77.0.0.output-00' does not exist Shutting down and cleaning up LinuxCNC... Running HAL shutdown script hm2_5i25.0: dropping AnyIO board at 0000:04:01.0 hm2/hm2_5i25.0: unregistered RTAPI_PCI: Unmapped 65536 bytes at 0xb6784000 hm2_pci: driver unloaded hm2: unloading Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/bridgeport/linuxcnc_debug.txt and /home/bridgeport/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
8 years 1 month ago #117229 by PCW
Does look like a issue with the isolated I/O section sine the analog section is found but not the digital so no or low field power, VIN jumper in wrong position setup jumper in wrong position etc, etc
8 years 1 month ago #117230 by cncnoob1979
Thanks PCW!
I traced it down to a faulty wiring. I'll keep a look out for this next time, until then, thanks sir!
NO Field or 5v, the wiring was in my transformer.
8 years 1 month ago #117232 by cncnoob1979
I thought I was out of the woods, but ....
Cr15 is Flashing Green and I am having following errors, so I can not home.
I really wish I remember what I was doing last year with this mill.
I really don't want to brick myself If I can help it. (if I haven't already)
bridgeport@bridgeport-H81M-S2PH ~ $ linuxcnc LINUXCNC - 2.8.0~pre1 pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM Machine configuration directory is '/home/bridgeport/linuxcnc/configs/axis_test' Machine configuration file is 'bridgeport.ini' Starting LinuxCNC... Found file(REL): ./bridgeport.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 hm2_pci: discovered 5i25 at 0000:04:01.0 hm2/hm2_5i25.0: Smart Serial Firmware Version 43 Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables hm2/hm2_5i25.0: 34 I/O Pins used: hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:04:01.0 Found file(REL): ./custom.hal note: MAXV max: 2.000 units/sec 120.000 units/min note: LJOG max: 2.000 units/sec 120.000 units/min note: LJOG default: 0.250 units/sec 15.000 units/min note: jog_order='XYZ' note: jog_invert=set([]) gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py NativeCAM info: inifile = /home/bridgeport/linuxcnc/configs/axis_test/bridgeport.ini NCAM_DIR = /home/bridgeport/linuxcnc/configs/axis_test/ncam SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py [RS274NGC]SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities:/home/stacie/linuxcnc/configs/bridgeport_axis/macros/ Real paths: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities Using default mill/menu.xml, no mill/menu-custom.xml found /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2644: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed mi = _action.create_menu_item() gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py Previous work not saved as current work /usr/bin/gladevcp:187: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated builder.add_from_file(xmlname) **** probe_screen GETINIINFO **** Preference file path: /home/bridgeport/linuxcnc/configs/axis_test/bridgeport.pref /usr/bin/gladevcp:298: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 17 gtk.main() joint 2 following error emc/task/taskintf.cc 944: Error on joint 2, command number 212 joint 0 following error emc/task/taskintf.cc 944: Error on joint 0, command number 241 joint 1 following error emc/task/taskintf.cc 944: Error on joint 1, command number 269 joint 1 following error emc/task/taskintf.cc 944: Error on joint 1, command number 360 joint 1 following error emc/task/taskintf.cc 944: Error on joint 1, command number 389 task: main loop took 0.109158 seconds
I confirmed at the 7i77 that I have 5v and 24v field power @ the terminal blocks. I have not moved any jumpers since Ive installed the 5i25 / 7i77 cards.
I have 4 amber LED's on and one flashing green one.
So is this my card(s) or am i looking at something else here?
8 years 1 month ago #117233 by PCW
Sounds like a tuning/setup issue
8 years 1 month ago #117234 by cncnoob1979
Well Im not getting anything from halscope from my encoders. Im going through the troubleshooting process now.
Which bit file would I need for my setup? I may try a reflash as well.
the 5i25_7i77x2 if I remember correctly right?
Ill download the manual again to figure out the reflash procedures. Im on 32bit so I shouldn't have to worry about getting corrupted.
Moderators: PCW, jmelson
Time to create page: 0.207 seconds
