5i25 and 7i77 Do I need to reflash?
- cncnoob1979
- Thank you received: 75
08 Sep 2018 21:43 #117225
by cncnoob1979
5i25 and 7i77 Do I need to reflash? was created by cncnoob1979
Hey guys! I started my machine after a long hiatus and for the life of me I can figure out what I was messing with when I last shut it down.
But I think i have a firmware issue. I am not getting a blinking light on the 7i77 and field power and 5v seems to be there.
sudo mesaflash --device 5i25 --readhmid >pinout.txt
The culprit is the
So I assume while I was messing with PP2 I must have gotten flashed while I thought I was being careful...
any help greatly appreciated...
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn3 (Out)
14 1 IOPort SSerial 0 TXData3 (Out)
2 2 IOPort SSerial 0 RXData3 (In)
15 3 IOPort SSerial 0 TXData2 (Out)
3 4 IOPort SSerial 0 RXData2 (In)
16 5 IOPort SSerial 0 TXData1 (Out)
4 6 IOPort SSerial 0 RXData1 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn6 (Out)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData6 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData5 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData4 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)The culprit is the
hm2_5i25.0: initialized AnyIO board at 0000:04:01.0
./bridgeport.hal:106: Pin 'hm2_5i25.0.7i77.0.0.output-00' does not existSo I assume while I was messing with PP2 I must have gotten flashed while I thought I was being careful...
bridgeport@bridgeport-H81M-S2PH ~ $ linuxcnc
LINUXCNC - 2.8.0~pre1
pickconfig: installed aux examples: /usr/share/linuxcnc/aux_examples/NativeCAM
Machine configuration directory is '/home/bridgeport/linuxcnc/configs/axis_test'
Machine configuration file is 'bridgeport.ini'
Starting LinuxCNC...
Found file(REL): ./bridgeport.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:01.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
Running HAL shutdown script
hm2_5i25.0: dropping AnyIO board at 0000:04:01.0
hm2/hm2_5i25.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0xb6784000
hm2_pci: driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/bridgeport/linuxcnc_debug.txt
and
/home/bridgeport/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminalPlease Log in or Create an account to join the conversation.
- Thank you received: 5326
09 Sep 2018 01:23 #117229
Replied by PCW on topic 5i25 and 7i77 Do I need to reflash?
Does look like a issue with the isolated I/O section sine the analog section is found but not the digital so no or low field power, VIN jumper in wrong position setup jumper in wrong position etc, etc
- cncnoob1979
09 Sep 2018 02:45 #117230
by cncnoob1979
Replied by cncnoob1979 on topic 5i25 and 7i77 Do I need to reflash?
Thanks PCW!
I traced it down to a faulty wiring. I'll keep a look out for this next time, until then, thanks sir!
NO Field or 5v, the wiring was in my transformer.
- cncnoob1979
09 Sep 2018 14:10 #117232
by cncnoob1979
I thought I was out of the woods, but ....
Cr15 is Flashing Green and I am having following errors, so I can not home.
I really wish I remember what I was doing last year with this mill.
I really don't want to brick myself If I can help it. (if I haven't already)
I confirmed at the 7i77 that I have 5v and 24v field power @ the terminal blocks. I have not moved any jumpers since Ive installed the 5i25 / 7i77 cards.
I have 4 amber LED's on and one flashing green one.
So is this my card(s) or am i looking at something else here?
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 3
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
Found file(REL): ./custom.hal
note: MAXV max: 2.000 units/sec 120.000 units/min
note: LJOG max: 2.000 units/sec 120.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
NativeCAM info:
inifile = /home/bridgeport/linuxcnc/configs/axis_test/bridgeport.ini
NCAM_DIR = /home/bridgeport/linuxcnc/configs/axis_test/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
[RS274NGC]SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities:/home/stacie/linuxcnc/configs/bridgeport_axis/macros/
Real paths:
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
Using default mill/menu.xml, no mill/menu-custom.xml found
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2644: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion 'gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Previous work not saved as current work
/usr/bin/gladevcp:187: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
**** probe_screen GETINIINFO ****
Preference file path: /home/bridgeport/linuxcnc/configs/axis_test/bridgeport.pref
/usr/bin/gladevcp:298: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 17
gtk.main()
joint 2 following error
emc/task/taskintf.cc 944: Error on joint 2, command number 212
joint 0 following error
emc/task/taskintf.cc 944: Error on joint 0, command number 241
joint 1 following error
emc/task/taskintf.cc 944: Error on joint 1, command number 269
emc/task/taskintf.cc 944: Error on joint 1, command number 360
emc/task/taskintf.cc 944: Error on joint 1, command number 389
task: main loop took 0.109158 seconds
09 Sep 2018 14:15 #117233
Sounds like a tuning/setup issue
- cncnoob1979
09 Sep 2018 14:33 #117234
by cncnoob1979
Well Im not getting anything from halscope from my encoders. Im going through the troubleshooting process now.
Which bit file would I need for my setup? I may try a reflash as well.
the 5i25_7i77x2 if I remember correctly right?
Ill download the manual again to figure out the reflash procedures. Im on 32bit so I shouldn't have to worry about getting corrupted.
09 Sep 2018 14:36 #117235
Your firmware is fine, no need to change it
- cncnoob1979
09 Sep 2018 15:00 #117237
by cncnoob1979
I just tried Path Pilot and it works fine.... with the exact same configuration that Im using in linuxcnc. The hal and Ini are derivatives of my linuxcnc configuration.
I can home, jog and use as normal. So the card/encoders/servo's functions correctly.... I did just build another linuxcnc master. Ill build the latest stable and see if this is my issue.
- cncnoob1979
09 Sep 2018 15:04 #117238
by cncnoob1979
Alright 2.7.14 build in progress. Ill update when its done and if that was my issue.
- cncnoob1979
09 Sep 2018 15:52 #117241
by cncnoob1979
Ok that did not work. Im on 2.7.14 and exact same symptoms. Path Pilot works fine.
I want to go through the relfash procedure. Peter please let me know which bit file I need to use. This may not be the issue as you have already pointed out, but I'm at my wits end. I never had any issue with my setup or configuration. I have even tried my backup configurations.
I copied over path pilots ini and hal file and tried that setup as well. Still the same issue (after editing them of course)
Something is squirrelly
Does anything pop out at you looking at my Hal and INI files? Maybe I changed something a year ago, but that doesnt explain Path Pilot working without a hitch, using the same configuration.
hal file
ini file
hal file
# Generated by PNCconf at Mon Jan 18 14:56:08 2016
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=5 num_pwmgens=5 num_stepgens=0 sserial_port_0=100xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt oneshot names=os1,os2,os3,os4,os5
loadrt not count=4
loadrt conv_float_s32 names=cnvf,cnvr,cnvs
loadrt debounce cfg=2
loadrt and2 count=12
loadrt or2 count=10
loadrt toggle count=1
loadrt toggle2nist count=1
loadrt flipflop names=ff1,ff2
loadrt near count=2
loadrt scale names=scale.sp,scale.jog,scale-fo,scale-ro,scale-so,scale-maxa
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt limit1 count=2
loadrt limit2 count=1
loadrt mux2 count=3
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
addf os1 servo-thread
addf os2 servo-thread
addf os3 servo-thread
addf os4 servo-thread
addf os5 servo-thread
addf not.0 servo-thread
addf not.1 servo-thread
addf not.2 servo-thread
addf cnvf servo-thread
addf cnvr servo-thread
addf cnvs servo-thread
addf debounce.0 servo-thread
addf and2.0 servo-thread
addf and2.1 servo-thread
addf and2.2 servo-thread
addf and2.3 servo-thread
addf and2.4 servo-thread
addf and2.5 servo-thread
addf and2.6 servo-thread
addf and2.7 servo-thread
addf and2.8 servo-thread
addf and2.9 servo-thread
addf and2.10 servo-thread
addf and2.11 servo-thread
addf or2.0 servo-thread
addf or2.1 servo-thread
addf or2.2 servo-thread
addf or2.3 servo-thread
addf or2.4 servo-thread
addf or2.5 servo-thread
addf or2.6 servo-thread
addf or2.7 servo-thread
addf or2.8 servo-thread
addf or2.9 servo-thread
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
addf ff1 servo-thread
addf ff2 servo-thread
addf near.0 servo-thread
addf near.1 servo-thread
addf scale.sp servo-thread
addf scale.jog servo-thread
addf scale-fo servo-thread
addf scale-ro servo-thread
addf scale-so servo-thread
addf scale-maxa servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf limit1.0 servo-thread
addf limit1.1 servo-thread
addf limit2.0 servo-thread
addf mux2.0 servo-thread
addf mux2.1 servo-thread
addf mux2.2 servo-thread
#################################### AXIS HAL ########################################
#########################################--- "ESTOP-OUT" ---##############
# "Estop output logic" ###
# "Enables 10CR to enable power up" ###
# "Drives DC Interlock relay" ###
# --- "ESTOP-OUT" ---#####################################################
net estop-out hm2_5i25.0.7i77.0.0.output-00
net machine-is-enabled hm2_5i25.0.7i77.0.0.output-01
# "Overrides" #
# "Read analog inputs from the override knobs. Full scale will be"#
# "approximately 24v. Scale the input accordingly. 1.0 = 100%" #
# "Scale up the raw values 100x so that when converted to" #
# "integers we have good resolution." #
# "The results will be between 0 and 2400." #
################"--- Feed Override ---"##################
# Convert from float to S32 #
# "Read in analog input and send to halui.feed-override"
# "Enable direct count input"
net scale_ovr => scale-fo.gain scale-ro.gain scale-so.gain
sets scale_ovr 100.0
#100
net fo-ena halui.feed-override.count-enable halui.feed-override.direct-value
sets fo-ena 1
# "Scale down the value to a percentage"
net scf-scale => halui.feed-override.scale
sets scf-scale 0.000852
net scf-raw scale-fo.in <= hm2_5i25.0.7i77.0.0.analogin0
net scf-raw-adj cnvf.in <= scale-fo.out
net scf-s halui.feed-override.counts <= cnvf.out
################"--- Rapid Override ---"#################
# "Read in analog input and send to halui.rapid-override"
net ro-ena halui.rapid-override.count-enable halui.rapid-override.direct-value
sets ro-ena 1
net scr-scale => halui.rapid-override.scale
sets scr-scale 0.00044
net scr-raw scale-ro.in <= hm2_5i25.0.7i77.0.0.analogin1
net scr-raw-adj cnvr.in <= scale-ro.out
net scr-s halui.rapid-override.counts <= cnvr.out
###############"--- Spindle Override ---"################
# "Read in analog input and send to halui.spindle-override"
net so-ena halui.spindle-override.count-enable halui.spindle-override.direct-value
sets so-ena 1
net scs-scale => halui.spindle-override.scale
sets scs-scale 0.0005
#0.0005
# "Add an offest so that we have a minimum override of 30%"
#net scs-offset => scale-so.offset
#sets scs-offset 100
net scs-raw scale-so.in <= hm2_5i25.0.7i77.0.0.analogin2
net scs-raw-adj cnvs.in <= scale-so.out
net scs-s halui.spindle-override.counts <= cnvs.out
# "External Pause/Resume Section" [Stop] #
setp debounce.0.delay 20
net pause-resume-btn and2.0.in0 and2.1.in0 <= hm2_5i25.0.7i77.0.0.input-17-not
net pause-on toggle2nist.0.is-on and2.0.in1 and2.3.in1 <= halui.program.is-paused
net run-on and2.1.in1 <= halui.program.is-running
net pause-sig or2.0.in0 <= and2.0.out
net resume-sig or2.0.in1 <= and2.1.out
net toggle-ok toggle.0.in <= or2.0.out
net togglesig toggle2nist.0.in <= toggle.0.out
net toggleon halui.program.pause <= toggle2nist.0.on
net toggleoff halui.program.resume <= toggle2nist.0.off
# "External Run/Step Section" [Start] #
net run-step-btn and2.2.in0 and2.3.in0 <= hm2_5i25.0.7i77.0.0.input-16
net idle-on and2.2.in1 <= halui.program.is-idle
net run-sig halui.mode.auto halui.program.run <= and2.2.out
net step-sig halui.program.step <= and2.3.out
# "This is how The External Step/Pause buttons function:" #
# "Pressing Run/Step will begin executing a program. #
# Pressing Hold/Resume while a program is running will pause the program. #
# Pressing Run/Step while a program is paused will single step the program. #
# Pressing Hold/Resume while a program is paused will return it to normal run mode."#
# "Manual Panel/Joystick Jog signals" #
# "JOG X" #
net jog-x-pos hm2_5i25.0.7i77.0.0.input-06 or2.4.in0
net jog-x-pos-p hm2_5i25.0.7i77.0.0.input-20 or2.4.in1
net or-out0 or2.4.out halui.jog.0.plus
net jog-x-neg hm2_5i25.0.7i77.0.0.input-07 or2.5.in0
net jog-x-neg-p hm2_5i25.0.7i77.0.0.input-21 or2.5.in1
net or-out1 or2.5.out halui.jog.0.minus
# "JOG Y" #
net jog-y-pos hm2_5i25.0.7i77.0.0.input-08 or2.6.in0
net jog-y-pos-p hm2_5i25.0.7i77.0.0.input-19 or2.6.in1
net or-out2 or2.6.out halui.jog.1.plus
net jog-y-neg hm2_5i25.0.7i77.0.0.input-09 or2.7.in0
net jog-y-neg-p hm2_5i25.0.7i77.0.0.input-18 or2.7.in1
net or-out3 or2.7.out halui.jog.1.minus
# "JOG Z" #
net jog-z-pos hm2_5i25.0.7i77.0.0.input-10 or2.8.in0
net jog-z-pos-p hm2_5i25.0.7i77.0.0.input-22 or2.8.in1
net or-out4 or2.8.out halui.jog.2.plus
net jog-z-neg hm2_5i25.0.7i77.0.0.input-11 or2.9.in0
net jog-z-neg-p hm2_5i25.0.7i77.0.0.input-23 or2.9.in1
net or-out5 or2.9.out halui.jog.2.minus
# "Using or2 with two inputs"
#net signal-a input-a => or2.0.in0
#net signal-b input-b => or2.0.in1
#net or-out or2.0.out => input
# "Joystick switches (currently unused)"
#net jog-continuous <= hm2_5i25.0.7i77.0.0.input-12
# "JOG Rates - Select the limited rate when we jog z minus" #
setp limit1.0.max 20
net jog-speed => limit1.0.in => mux2.0.in0
net jog-speed-lim <= limit1.0.out => mux2.0.in1
net jog-z-neg => mux2.0.sel
net jog-speed-sel <= mux2.0.out => halui.jog-speed
# "Home switch inputs" #
net home-x <= hm2_5i25.0.7i77.0.0.input-13
net home-y <= hm2_5i25.0.7i77.0.0.input-14
net home-z <= hm2_5i25.0.7i77.0.0.input-15
# "X AXIS" #
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---"X AXIS PWM Generator signals/setup"---#
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out
# "X AXIS enable _all_ sserial pwmgens"#
net x-enable hm2_5i25.0.7i77.0.1.analogena
# ---"X AXIS Encoder feedback signals/setup"---#
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---"X AXIS home / limit switch signals"--- #
net home-x => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# "Y AXIS" #
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
# ---"Y AXIS PWM Generator signals/setup"---#
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
# ---"Y AXIS Encoder feedback signals/setup"---#
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
# ---"Y AXIS home / limit switch signals"--- #
net home-y => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# "Z AXIS" #
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
# ---"Z AXIS PWM Generator signals/setup"---#
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
# ---"Z AXIS Encoder feedback signals/setup"---#
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.02.position
net z-vel-fb <= hm2_5i25.0.encoder.02.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
# ---"Z AXIS home / limit switch signals"--- #
net home-z => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# "SPINDLE" #
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
setp pid.s.maxerror .0005
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---"SPINDLE control signals"--- #
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
#net spindle-enable <= motion.spindle-on
#net spindle-cw <= motion.spindle-forward
#net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
# ---"SPINDLE at speed signals"--- #
sets spindle-at-speed true
# "MISC SIGNALS" #
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net MDI-mode halui.mode.is-mdi
# ---"coolant signals"---#
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# "Probe input & output" #
#net probe-in <= hm2_5i25.0.7i77.0.0.input-23 => or2.3.in0
#net toolset-in <= hm2_5i25.0.7i77.0.0.input-24 => or2.3.in1
#net probe-signal <= or2.3.out => motion.probe-input
#"Output a short pulse to the probe LED/Beeper on contact"
#setp os5.falling FALSE
#setp os5.rising TRUE
#newsig os5Time float
#net os5Time => os5.width
#sets os5Time 0.02
#net probe-signal => os5.in
#net probe-led <= os5.out => hm2_5i25.0.7i77.0.0.output-10
net probe-in => motion.probe-input
# ---"motion control signals"---#
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---"estop signals"--- #
net estop-out => iocontrol.0.emc-enable-in
# "Manual Tool Change" #
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
# "SHARED JOGWHEEL MPG" #
net joint-selected-count <= hm2_5i25.0.encoder.03.count
######### "for axis x MPG" #########
setp axis.0.jog-vel-mode 0
net selected-jog-incr => axis.0.jog-scale
#net jog-ena-x => axis.0.jog-enable
net joint-selected-count => axis.0.jog-counts
######### "for axis y MPG" #########
setp axis.1.jog-vel-mode 0
net selected-jog-incr => axis.1.jog-scale
#net jog-ena-y => axis.1.jog-enable
net joint-selected-count => axis.1.jog-counts
######### "for axis z MPG" #########
setp axis.2.jog-vel-mode 0
# "Limit Z motion, should be about 20 FPM"
setp limit1.1.max [MPG]Z_MINUS_LIMIT
net selected-jog-incr => limit1.1.in
net selected-jog-incr-z <= limit1.1.out => axis.2.jog-scale
#net jog-ena-z => axis.2.jog-enable
net joint-selected-count => axis.2.jog-counts
# "Scale the jog rate (FPM) to an increment per Handwheel count"
setp scale.jog.gain [MPG]HAND_WHEEL_SCALE
net jog-speed => scale.jog.in
# "MPG JOG SELECTED" #
net jog-ena-z hm2_5i25.0.7i77.0.0.input-25 => axis.2.jog-enable
net jog-ena-z-not hm2_5i25.0.7i77.0.0.input-25-not => and2.11.in0
net jog-ena-x hm2_5i25.0.7i77.0.0.input-24 => axis.0.jog-enable
net jog-ena-x-not hm2_5i25.0.7i77.0.0.input-24-not => and2.11.in1
net jog-ena-y and2.11.out => axis.1.jog-enable
sets selected-jog-incr .000001
sets jog-speed 100
# "POST GUI FILE BERTHA Jog signals" #
#net jog-speed <= gscreen.jog-spd-out
#net jog-inc <= screen.jog-inc-out
#net jog-ena-x <= gscreen.jog-enable-x-out
#net jog-ena-y <= gscreen.jog-enable-y-out
#net jog-ena-z <= gscreen.jog-enable-z-outini file
# Generated by PNCconf at Fri Jan 15 18:07:07 2016
[EMC]
MACHINE = bridgeport
DEBUG = 0
[DISPLAY]
#DISPLAY = gmoccapy
DISPLAY = axis
EMBED_TAB_NAME=Huanyang VFD
#EMBED_TAB_LOCATION=ntb_user_tabs
EMBED_TAB_COMMAND=halcmd loadusr -Wn vfd gladevcp -c vfd -x {XID} -u handler.py huanyang.glade
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_COMMAND=halcmd loadusr -Wn probe_screen gladevcp -c probe_screen -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
#******** required 'NativeCAM' items:********************************************
## ncam.ui is required in this directory, relative or absolute
GLADEVCP = -U --catalog=mill ncam.ui
PROGRAM_PREFIX = ncam/scripts/
# NCAM_DIR ***'MUST'*** match the first dir of SUBROUTINE_PATHS
NCAM_DIR = ncam
EDITOR = kate
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.20000
MIN_SPINDLE_OVERRIDE = 0.050000
INTRO_TIME = 3
PROGRAM_PREFIX = /home/stacie/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 2.0
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
FEATURES=30
PARAMETER_FILE = linuxcnc.var
#******** required 'NativeCAM' items will be created the first time***
# "NCAM_DIR must be specified"
[TOOLSENSOR]
# Control probe rapid feed (in machine units per minute)
RAPID_SPEED = 100
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = bridgeport.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 6.0
MAX_VELOCITY = 6.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1.003
MIN_FERROR = 1.003
MAX_VELOCITY = 3.10
MAX_ACCELERATION = 5.0
P = 150
I = 0
D = 0
FF0 = 0
FF1 = 2.74
FF2 = 0.003
BIAS = 0
DEADBAND = 0.00009
MAX_OUTPUT = 10
ENCODER_SCALE = -50800
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -17.755
MAX_LIMIT = 0.04
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0.5
HOME_LATCH_VEL = 0.017
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.003
MIN_FERROR = 0.003
MAX_VELOCITY = 3.10
P = 150
I = 0
D = 0
FF0 = 0
FF1 = 2.74
FF2 = 0.003
BIAS = 0
DEADBAND = 0.000059
MAX_OUTPUT = 10
OUTPUT_SCALE = 10
MIN_LIMIT = -11.373
MAX_LIMIT = 0.303
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 0.500000
HOME_LATCH_VEL = 0.016667
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.003
MIN_FERROR = 0.003
MAX_VELOCITY = 2.5
P = 150
I = 0
D = 0
FF0 = 0
FF1 = 2.74
FF2 = 0.003
BIAS = 0
DEADBAND = 0.000059
MAX_OUTPUT = 10
OUTPUT_SCALE = 10
MIN_LIMIT = -4.465
MAX_LIMIT = 0.069
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 10
# Handwheel
[MPG]
HAND_WHEEL_SCALE = 0.00000016
Z_MINUS_LIMIT = 0.000008Please Log in or Create an account to join the conversation.
Time to create page: 0.596 seconds
