Using Brushless drives with brushed motors
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
25 Sep 2018 00:14 #117944 by Catch22
I read somewhere that you can use brushless servo drives with brushed servo motors. I am looking at some Advanced Motion Controls Be25a20 that is brushless and I want to make sure that I can use them with my brushed servo motors. Can anyone verify this for me.
Thanks Mike
25 Sep 2018 01:53 #117945 by jmelson
Replied by jmelson on topic Using Brushless drives with brushed motors
If the drives use the simple six-step scheme, where they only drive 2 of the 3 output terminals at a time, and only use the Hall commutation signals, this can be done by wiring a permanent configuration on the Hall inputs. You would have 2 of the hall inputs set to one condition (either high or low) and the one other input to the opposite condition. This would force the drive to always drive the same 2 output terminals.
The data sheet may have instructions on how to do this.
If the drive in question is sinusoidal or uses encoder feedback, then this cannot(generally) be done.
Jon
The following user(s) said Thank You: Catch22
25 Sep 2018 04:15 #117947 by cmorley
Moderators: PCW, jmelson
Time to create page: 0.114 seconds
