7i77 not sending any voltage on TB5 pins 3 and 4
- COlger81
- Thank you received: 6
15 Nov 2018 13:13 #120751
by COlger81
Replied by COlger81 on topic 7i77 not sending any voltage on TB5 pins 3 and 4
Looks to be that e_stop latch would accomplish this?
- Thank you received: 7478
15 Nov 2018 15:07 #120753
Replied by tommylight on topic 7i77 not sending any voltage on TB5 pins 3 and 4
I would not recommend that, it should be enabled only by machine enable. The reason being, if anything goes wrong on the encoders or wiring or anything else, Linuxcnc will not trigger an E-stop, it will however trigger a disable to the drives rendering them motionless.
- COlger81
15 Nov 2018 15:21 #120757
by COlger81
I used a different method. I don't see how this would hinder an estop?
#----PINS---ESTOP---START
net estop-in iocontrol.0.emc-enable-in <= and2.0.out
net internal-estop and2.0.in1 <= iocontrol.0.user-enable-out
net remote-estop and2.0.in0 halui.estop.activate => hm2_7i92.0.7i77.0.0.input-20-not
net estop-in <= hm2_7i92.0.7i72.0.2.output-00
net estop-in halui.machine.on
#----PINS---ESTOP---END
15 Nov 2018 21:38 #120781
Where or how did you read that ! It does not hinder E-stop, it will hinder the ability of Linuxcnc to disable the drives in many cases where it is implicitly necessary to do so for safety and prevent damage to the machine, like any missconfiguration during setup, run out of motors during tuning, in case an encoder line brakes during normal use, etc.
Time to create page: 0.793 seconds
