Mesa card address syntax
- Nitram
- Thank you received: 15
10 Oct 2018 10:11 - 10 Oct 2018 10:12 #118632
by Nitram
Mesa card address syntax was created by Nitram
Hi.
I have a mill which was retrofitted a few years ago with a 5i24 and three 7i84's.
For my own interest I would like to decipher one part of the syntax when accessing pins.
A typical pin from the HAL file is:
hm2_5i24.0.7i84.0.1.output-05
so I suspect the section "5i24.0" refers to the first 5i24 i.e. the zero numbered 5i24 board (in this case there is only one)
then "7i84.0.1" where given that there are three other 7i84 boards the "1" at the end of this phrase refers to the second 7i84 board etc.
What I cannot decipher is what the middle 0 refers to i.e. between 7i84. and .1
In the same way this address:
hm2_7i76e.0.7i76.0.0.output-07
what does the middle zero i.e. hm2_7i76e.0.7i76.0.0.output-07 refer to?
Thanks,
Marty.
Thanks,
Marty.
Last edit: 10 Oct 2018 10:12 by Nitram.
- Thank you received: 5325
10 Oct 2018 13:26 #118637
Replied by PCW on topic Mesa card address syntax
That is the "port" address
The host side of the sserial interface is divided into 1 to 4 "ports" numbered 0..3
each port can have up to 8 channels for a maximum of 32 connected devices
The sserial manual page as a little information about this
There is an alternate numbering scheme you can invoke that uses the sserial devices unit number instead of port/channel addressing.This has the advantage that you can swap sserial CAT 5 cables around without changing the I/O structure.
- Thank you received: 4654
11 Oct 2018 10:09 #118667
For fun, look in your HAL file to find "loadrt hostmot2" and change that to "loadrt hostmot2 use_serial_numbers=1"
Then you get a different naming scheme (which I prefer) where the smart-serial card pins contain the card serial number.
This can save ambiguity.
Replied by andypugh on topic Mesa card address syntax
Time to create page: 0.080 seconds
