Updating 7i77 firmware failing.
14 Oct 2018 15:28 #118776 by sliptonic
Updating 7i77 firmware failing. was created by sliptonic
Full disclosure: This is a machinekit install
I'm updating my mill and trying to get rid of a persistent warning:
"hm2/hm2_5i25.0: Warning: sserial remote device 7i77 channel 0 has old firmware that should be updated"
The mill has three servos and a stepper for the 4th axis. I flash the 5i25 like this:
sudo mesaflash --device 5i25 --write 5i25_7i77_bstech.bit
And everything works correctly but the above warning shows on startup.
I downloaded the latest serial firmware and have tried to update the 7i77 without success. Log follows. Note, I also tried this as root which fails with a different error that it won't run as root. So I guess this is a difference between LCNC and MK. Can someone point me to a MK friendly upgrade procedure?
brad@millstone:~/utils/linuxcnc$ ./update7i77
move 7I77 W4 and W12 to right hand positions
cycle 7I77 field power and 5V power and hit return
updating 7I77 field I/O
msgd:0 stopped
rtapi:0 stopped
rtapi_msgd command:  /usr/libexec/linuxcnc/rtapi_msgd --instance=0 --rtmsglevel=1 --usrmsglevel=1 --halsize=524288
rtapi_app command:  /usr/libexec/linuxcnc/rtapi_app_rt-preempt --instance=0
update7i77d.hal:4: insmod failed, returned -1:
rtapi_app_main(setsserial): -1 Operation not permitted
See /var/log/linuxcnc.log for more information.
updating 7i77 analog out
msgd:0 stopped
rtapi:0 stopped
update7i77a.hal:4: insmod failed, returned -1:
now move 7I77 W4 and W12 to the left hand positiona
and cycle field power and 5V power
^Cbrad@millstone:~/utils/linuxcnc$
14 Oct 2018 17:00 #118783 by andypugh
Replied by andypugh on topic Updating 7i77 firmware failing.
That isn't necessarily wrong, the setsserial utility always exits with an error. (documented behaviour..)
linuxcnc.org/docs/devel/html/man/man9/setsserial.9.html
Have you power cycled the 7i77 after the flash?
14 Oct 2018 18:23 #118787 by sliptonic
Replied by sliptonic on topic Updating 7i77 firmware failing.
Yes. The same warning returns
14 Oct 2018 19:31 #118791 by PCW
Replied by PCW on topic Updating 7i77 firmware failing.
Can you try running say the update7i77d.hal script a bit at time a via
halrun to see where it fails? that is, type the commands in the script
one at a time in a halrun session.
Maybe the firmware is not installed or in the wrong place or setsserial has some generic problem with the MK environment
14 Oct 2018 20:14 #118795 by sliptonic
Good call. Nailed it. The machinekit docs say, "The firmware should be placed somewhere in the /lib/firmware/hm2 tree, where the Linux firmware loading macros can find it." But it needs to be exactly in /lib/firmware/hm2/sserial.
Probably should have caught that myself. Thank you.
Moderators: PCWjmelson
Time to create page: 0.137 seconds
