7i76e why 24v?
- Camren360
01 Nov 2018 15:48 #119768
by Camren360
7i76e why 24v? was created by Camren360
Hi all,
I am new to this whole process, but I have been doing a lot of review on setting up my Mesa 7i76e board, and I keep seeing that it should be powered by a 24v power supply. I was just wondering why?
If my Drivers are independently powered by a 36v power supply can I get away with just powering my board with 5v?
The only thing I am currently using my board for is Step/Dir, and Limit Switches.
- BigJohnT
- Thank you received: 994
01 Nov 2018 16:29 #119771
by BigJohnT
Replied by BigJohnT on topic 7i76e why 24v?
I/O is typically 24vdc, encoders and step and direction signals are typically 5vdc and stepper drives are anything from 12v to hundreds of volts. IIRC the I/O needs 7v or something like that as a minimum (it's in the 7i76e manual).
JT
JT
- Thank you received: 4149
01 Nov 2018 19:39 #119781
Replied by rodw on topic 7i76e why 24v?
Plus the higher voltage (24v) will make your system more immune to noise.
- Camren360
06 Nov 2018 22:11 #120123
by Camren360
Replied by Camren360 on topic 7i76e why 24v?
Update I used an ATX Power Supply to power the board with 12v and it is working just fine. I don't think noise will be too much of a factor. If it is then I will consider sourcing a 24v power supply. Ultimately what this allows me to do is mount the board inside my computer case, and run it off that Power Supply.
Time to create page: 0.433 seconds
