Star Tech parallel port
14 Nov 2018 13:00 #120672 by i_r_machinist
Star Tech parallel port was created by i_r_machinist
Looking at buying a star tech parallel port for a new install. Anyone have input positive or negative? Instructions on how to load the driver?
i_r_
www.amazon.com/Port-Express-Profile-Para...port#customerReviews
14 Nov 2018 14:56 #120683 by Todd Zuercher
Replied by Todd Zuercher on topic Star Tech parallel port
In Linux you usually shouldn't need to install a driver for a parallel port card. If you do then there is a good chance the card won't work. I don't have any experience with that particular card.
14 Nov 2018 16:32 #120687 by jmelson
Replied by jmelson on topic Star Tech parallel port
If you just need plain parallel port, then most cards will work. If you need EPP mode (for Pico Systems or Mesa controller boards) then it gets more complicated. For EPP, I supply SYBA SD-PEX10005 cards for the PCIe slots. I recommend SIIG parallel port cards for the older PCI slots.
There have been a very few cards that are so far from the classic parport register layout that they only work with a Windows driver. I'm not too sure which these cards are.
Jon
Moderators: PCW, jmelson
Time to create page: 0.073 seconds
