Yaskawa usarem motors, Amc be25a20 making it work?
- JR1050
- Thank you received: 31
24 Nov 2018 04:57 #121285
by JR1050
Yaskawa usarem motors, Amc be25a20 making it work? was created by JR1050
I have two Yaskawa ac servos, usarem 05c and 03c , they ac servos that use an 8192 absolute encoder. They don't have hall switches for communtation. The Yaskawa drives are out of my price range, so I'd like to use Amc be25a20 drives, as I already have them. These are intended for bldc motors that have hall switches and are analog ,+- 10v. Would it be possible to use the bldc component to create the hall signals and still feed the drive an analog signal? Present set up is 7i90 and 7i33
- Thank you received: 4654
26 Nov 2018 13:25 #121364
Replied by andypugh on topic Yaskawa usarem motors, Amc be25a20 making it work?
It might be possible, if you can find a way to convert the encoder feedback into an angle.
A better solution would be STMBL, except that currently there are none available due to the main power IC being discontinued.
github.com/rene-dev/stmbl/blob/master/do...tting%20Started.adoc
It "talks" Yaskawa absolute and can be commanded by Mesa smart-serial.
The following user(s) said Thank You: JR1050
- JR1050
27 Nov 2018 19:10 - 28 Nov 2018 17:25 #121483
by JR1050
Replied by JR1050 on topic Yaskawa usarem motors, Amc be25a20 making it work?
From reading thru massive amounts of Yaskawa literature, it seems the actual encoder has standard differential signals and the serial absolute signal is requested by the Yaskawa drive/host controller. This being the case, and this is an educated guess, I can use the bldc component to generate the hall signals by setting it up as an incremental encoder and use the marker channel for home?I attached the Yaskawa paper on the absolute encoder.
Last edit: 28 Nov 2018 17:25 by JR1050.
30 Nov 2018 15:36 #121636
It isn't immediately obvious from scanning that document if there is an index signal.
even if there isn't you might be able to home the motors using bldc in direct current mode. How accurate that is depends on the static load on the motors. (ie it is fine for a spindle, but unlikely to work well on a moving-knee Z axis)
- JR1050
01 Dec 2018 05:04 - 01 Dec 2018 06:41 #121671
by JR1050
Here is a short video of where I'm at, encoder counts, index channel appears to work. I'm not getting any hall signals though . The bldc component is rather busy, on the man page there are several references to personality, what do these pertain to? What would cause the lack of hall signal generation? I'll attach the Hal and ini files.
Last edit: 01 Dec 2018 06:41 by JR1050.
- Thank you received: 7478
01 Dec 2018 06:11 #121673
Replied by tommylight on topic Yaskawa usarem motors, Amc be25a20 making it work?
Incremental encoders have A, B, and Z channels.
Yaskava has A, B, and C channels, all of them give a pulse train that changes the density while rotating and that change is shifted on all channels from each other.
- JR1050
01 Dec 2018 07:02 - 01 Dec 2018 07:06 #121674
by JR1050
The paper from Yaskawa above states the a and b channels are standard incremental quad channels and the c is the marker pulse(you can see the index enable go low to high in the video). The serial data is sent thru channel A on start up, on a 15 bit encoder, then it reads incrementally. There are several manuals on these motors and drives, TSE-s800-2.4e and TSE-s800-15c do a good job at explaining how the encoder works. The wiring scheme is the same for both their incremental and absolute encoders with the exception of the battery backup being excluded on the incremental version, they call the marker/home/Z channel C on both. Ill bet they are they same .They are not gray code output.They count the specified distance on the dro based on the input scale.These are also older (1995 vintage) motors.
I am by no means an expert on this, as its new to me, but based on the info ive read and what Ive observed, Id say its looking like this will work if i can get the hall signals to output. Id bet im missing a parameter or don't have the component setup right...
This is worth figuring out, if it works it will save anyone who wants to use Yaz motors and not have to pay the big yaz drive cost.
Last edit: 01 Dec 2018 07:06 by JR1050.
01 Dec 2018 10:55 #121676
"qiH" needs you to send an "init" signal:
That starts a search-for-index.
I would change your enable section of HAL to look like
(the q, i, a etc flags become a bitmask that becomes "personality" and that controls what pins are created, but the compiler doesn't know that the user shouldn't be setting those and auto-documents them)
4 bit OUT FALSE bldc.0.hall1-out
4 bit OUT FALSE bldc.0.hall2-out
4 bit OUT FALSE bldc.0.hall3-out
4 bit I/O FALSE bldc.0.index-enable
4 bit IN FALSE bldc.0.init
4 bit OUT FALSE bldc.0.init-done
4 float IN 0.2 bldc.0.initvalue
4 float IN 90 bldc.0.lead-angle
4 float OUT 0 bldc.0.out
4 float OUT 0 bldc.0.out-abs
4 bit OUT FALSE bldc.0.out-dir
4 float OUT 0 bldc.0.phase-angle
4 s32 IN 0 bldc.0.rawcounts
4 bit IN FALSE bldc.0.rev
4 float OUT 0 bldc.0.rotor-angle
4 s32 OUT 0 bldc.0.time
4 float IN 0 bldc.0.valueThat starts a search-for-index.
# axis enable chain
net emcmot.00.enable <= joint.0.amp-enable-out #hal pin enables the amp
net emcmot.00.enable => hm2_7i90.0.pwmgen.00.enable #mesa pin enables pwm
net emcmot.00.enable => bldc.0.init #magnetically home the motor
net enable-X-control <= bldc.0.init-done
net enable-X-control => pid.0.enable #hal pin enables pidAll references to "personality" are auto-generated and should be ignored.The bldc component is rather busy, on the man page there are several references to personality, what do these pertain to?
- JR1050
21 Dec 2018 22:23 - 22 Dec 2018 01:13 #122735
by JR1050
Some info, progress , issues
It took a significant effort to get info on these motors. Yaskawa motors with an FJ suffix were made for Fuji and Yaskawa USA has little to no info , but.... I do have this
All Yaskawa ac motors are 8 pole
Fuji used incremental encoders , they will be utop i or h and the number after x 10 is the count. As far as I can tell FJ11 is usually a 2000 ppr incremental. All Yaskawa encoders are the same hardware wise, they are programmed to count and absolute/incremental. That was from Yaskawa direct.
Yaskawa aligns the marker pulse with motor zero.
In the video below is the drive running the motor in current mode, it is be run off a watch battery.
My present issue is I'm not getting any analog voltage out of the 7i33, I get pid, as putting some P and D on it stiffened the shaft up. I Could the bldc component be clashing somehow with the pwm out put? Since the marker and motor zero are already aligned, does it still need magnetic homing?
Addendum.... first jogs. Motor cogs some. On the right track.
Last edit: 22 Dec 2018 01:13 by JR1050.
22 Dec 2018 01:13 #122741
No, you should use "qi" mode.
But just bear in mind that "motor zero" has more than one definition. A+ B- C- is a common one (and the Mesa one) bit it is not universal.
Time to create page: 0.658 seconds
