7i76E Through Ethernet Switch
- phillc54
- Thank you received: 2100
02 Dec 2018 04:38 #121701
by phillc54
7i76E Through Ethernet Switch was created by phillc54
Is it feasible to connect one PC to two (or more) machines (each fitted with a single 7i76E) via an ethernet switch.
There will only be one machine operational at any one time.
Cheers, Phill.
Cheers, Phill.
- Thank you received: 5325
02 Dec 2018 06:16 #121704
Replied by PCW on topic 7i76E Through Ethernet Switch
Yes, you can do this but expect that the overall read and write times will increase
slightly, since the switch not forward the packets until completely received.
Also not sure but you may also need to change the IP address of one the 7I76E cards to avoid confusing the switch.
- Thank you received: 4654
03 Dec 2018 14:58 #121752
Replied by andypugh on topic 7i76E Through Ethernet Switch
Multiple NICs in the PC might be easier.
- phillc54
03 Dec 2018 22:06 #121776
by phillc54
Replied by phillc54 on topic 7i76E Through Ethernet Switch
Unfortunately it is only a single NIC Gigabyte Brix and I think the only ethernet addition is via a USB dongle.
- Thank you received: 4149
04 Dec 2018 00:50 #121789
Phil, if you have a look on Aliexpress/Alibaba, you will find some 2 NIC and 4 NIC J1900/ N3160 USFF PC's which should work fine with Mesa ethernet cards. PCW ages ago mentioned a 2 NIC Zotec PC but try as I might I could not find a source in Australia so went with a Brix.
Something Like this
www.aliexpress.com/store/product/Hystou-...st_4937556.subject_3
Replied by rodw on topic 7i76E Through Ethernet Switch
Something Like this
The following user(s) said Thank You: phillc54, Immutef
Time to create page: 0.749 seconds
