following error while homing only
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Dec 2018 21:52 #121775 by billykid
following error while homing only was created by billykid
I noticed that by running homing sometimes a random axis give following error.
after also working for hours no problem.
the system is a closed loop 5i23-7i40 home switch + index.
I do not understand why only while homing ...
Mauro
03 Dec 2018 23:23 #121783 by PCW
Replied by PCW on topic following error while homing only
This can be related to homing to index because of the step in encoder position
when index is detected.
Do you have the per axis index-enable signals connected to the PID
components index enable pin?
  • billykid
  • Platinum Member
  • Platinum Member
04 Dec 2018 21:04 #121831 by billykid
Replied by billykid on topic following error while homing only
this is the hal section of the x axis, however also y and z have the same defect.
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-vel-fb => pid.x.feedback-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i23.0.pwmgen.01.output-type 1
setp hm2_5i23.0.pwmgen.01.scale [AXIS_0]OUTPUT_SCALE
net x-output => hm2_5i23.0.pwmgen.01.value
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out => hm2_5i23.0.pwmgen.01.enable
setp hm2_5i23.0.encoder.01.counter-mode 0
setp hm2_5i23.0.encoder.01.filter 1
setp hm2_5i23.0.encoder.01.index-invert 0
setp hm2_5i23.0.encoder.01.index-mask 0
setp hm2_5i23.0.encoder.01.index-mask-invert 0
setp hm2_5i23.0.encoder.01.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i23.0.encoder.01.position
net x-vel-fb <= hm2_5i23.0.encoder.01.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i23.0.encoder.01.index-enable
net x-pos-rawcounts <= hm2_5i23.0.encoder.01.rawcounts
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
#net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
04 Dec 2018 21:52 #121834 by PCW
Could you include the entire hal file as an attachment?
  • billykid
  • Platinum Member
  • Platinum Member
04 Dec 2018 22:02 #121835 by billykid
File Name: La_mia_cnc-pwm.hal
File Size:15 KB
04 Dec 2018 22:33 #121838 by PCW
OK look normal, what are your following error settings?
There can be a (supposedly small) error spike when index is detected
because the commanded and feedback position have a large step (especially if this is the first home after a startup)
This is patched around in the PID component by using the previous cycles PID output when the index is detected (index-enable falling edge) since the calculated derivatives would be broken in this case. This (one cycle stale PID output) will cause a small glitch especially if index happens during accelerated motion
You might try homing without index to see if the error is still there, and if so
a plot of the following error when homing might shed some light on whats happening.
05 Dec 2018 06:18 #121845 by tommylight
Replied by tommylight on topic following error while homing only
You should check the tuning, use halscope to track following error.
  • billykid
  • Platinum Member
  • Platinum Member
05 Dec 2018 09:23 #121854 by billykid
thanks Pcw
max_ferror = 1 min_ferror = 0.2 I had put them high for the tests.
before using index homing had no problems.
unfortunately this morning it always works and I can not analyze the error ... I will try again calmly.
home search_vel = 5 will not be high I think.
Thanks Tommy
I think the pid is well calibrated because it is perfect at any speed and never goes wrong. seen with halscope never exceeds 5 mv including start and stop at F1000 .. F300 2 mv.
1 mv = 0.001 mm
I feel very good values after I mounted 3600 ppr x 4 14400 cpr encoders
Mauro
Moderators: PCW, jmelson
Time to create page: 0.307 seconds
