7i73 LCD interface defective
- Mike_Eitel
- Thank you received: 183
21 Dec 2018 19:23 #122714
by Mike_Eitel
7i73 LCD interface defective was created by Mike_Eitel
Hi pcw
I had a severe incident run stepper DC through my Mesa combo.
Thx again for the 7i76e replacement.
I did a compete reconstruct to my hw. And have to solve the last problem now.
I know in the meanwhile that the current from my 80dc ( I'm quite sure minus) found the earthing point in the housing of my LCD....
Nevertheless the 7i73 seams to work, only I get no LCD working ( replaced by new one)
Is there a way to find out if the 7i73 is partial defective.
Thx in advance
Mike
Thx in advance
Mike
- Thank you received: 5325
21 Dec 2018 19:42 #122718
Replied by PCW on topic 7i73 LCD interface defective
Yeah, probably some of the I/O bits of the PIC are damaged
We test these with a loopback fixture and test program
You could try disabling the LCD (by setting the sserial mode) and see if the LCD output pins have sensible output levels since damaged pins may have bad (neither high or low) levels
- Mike_Eitel
21 Dec 2018 20:07 #122720
by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD interface defective
OK, good idea.
will have to setup a test configuration for that.
I never did so fine pins, but if I replace the Pic.. Can I reprogram the chip?
21 Dec 2018 21:24 #122729
You need to have (or borrow) a PIC programmer to do this
- Mike_Eitel
21 Dec 2018 21:35 #122730
by Mike_Eitel
I ordered 4 chips and a programmer already.
I'm normally not in Pic, did quite some Avr's. But it is not bad to be a bit flexible and have some microchip knowledge too.
Is there somewhere a file to download and is it easy to transfer?
Thx Mike
Thx Mike
21 Dec 2018 22:56 #122737
- Mike_Eitel
22 Dec 2018 09:25 #122746
by Mike_Eitel
Big THX
Fast and customer oriented as always.
Will be a real chalange to replace that Pic, but looking forward...
Mike
Mike
Time to create page: 0.390 seconds
