Someone used Leadshine EtherCAT Stepper Drives?
- Grotius
- Thank you received: 2349
22 Dec 2018 23:00 #122763
by Grotius
Someone used Leadshine EtherCAT Stepper Drives? was created by Grotius
I was wondering if someone has already used the ethercat compatible stepper drives?
For example :
Leadshine DM522-CAN DM-CAN Serie EtherCAT Stepper Drives
Costs about 75 $ a piece relating to 250 $ a piece for EL7041
For example :
- pl7i92
- Thank you received: 358
29 Dec 2018 15:49 #123092
by pl7i92
Replied by pl7i92 on topic Someone used Leadshine EtherCAT Stepper Drives?
you may Better go for standard DM556 and use a real ethernet BOB
this gives you way more options
the CAn are for standalone Systems designed not realy for CNC stuff as you run syncronised axis
- Machinen
03 Jan 2019 15:58 #123412
by Machinen
Replied by Machinen on topic Someone used Leadshine EtherCAT Stepper Drives?
I doubt it. (As I have seen nothing.) But will be certainly interested if you took this task on yourself and then share with other kids in class.
I would be also interested if someone tested the offerings from Trinamic. Could be better than this Leadshine.
(Do you have any experience with EL7041? Does it really have such terrible encoder counter maxing out at 0.4 Mpulses per second?)
- Thank you received: 7497
03 Jan 2019 19:02 #123419
Replied by tommylight on topic Someone used Leadshine EtherCAT Stepper Drives?
Here you go, not much but still useful :I would be also interested if someone tested the offerings from Trinamic. Could be better than this Leadshine.
- Machinen
03 Jan 2019 21:24 #123431
by Machinen
Thats nice and I think that I have already seen this, but I meant the mid last year EtherCAT slave ICs for motor control and GPIO based stepper drivers.
- theshade
- Thank you received: 5
13 May 2020 08:19 #167622
by theshade
Replied by theshade on topic Someone used Leadshine EtherCAT Stepper Drives?
Hello,
Have you heard anything new relating to that?
I just ordered some to experiment..
What would be needed to make them work? Are you aware of example hal or ini files that I could use?
Would one need to write C code in linuxcnc-ethercat or would it be feasible with setting and configuring registers in xml files?
Also does it make sense to go that way for a gantry CNC using the generic etherlab driver?
Thank you in advance.
- chimeno
- Thank you received: 125
14 May 2020 17:13 #167764
by chimeno
Replied by chimeno on topic Someone used Leadshine EtherCAT Stepper Drives?
Hi @theshade
simply using the generic linuxcnc-ethercat configuration you have enough to control it,Do you have any manual of PDO registers and configuration?
Greeting
Chimeno
Greeting
Chimeno
