Performance difference between Mesa 6i24 / 6i25?
- 0ddbod
- Topic Author
7 years 9 months ago #123428
by 0ddbod
Performance difference between Mesa 6i24 / 6i25? was created by 0ddbod
Hello,
I'm looking at retrofitting a small lathe with linuxcnc using Mesa boards, the lathe has fanuc red cap servos so I intend to drive these using 8i20 drives, I understand that to control the servos in torque mode needs a fast servo loop, to this end is there any performance difference between using either the 6i25 card or the 6i24-25?
The 6i24-25 has more capacity for bigger 50 pin daughter cards, but I've worked out what I need and it should be comfortable with the 6i25 with a 7i85 for encoder input and serial connection to the 8i20 drives and additional serial i/o board, the second port would have a 7i76 for general i/o and spindle analog control.
The 6i25 setup looks the best choice and the cheapest but Is there any performance benefit to using 6i24-25 or will the PC be the limiting factor for the max servo loop frequency?
Any comments or info much appreciated
- Thank you received: 1480
7 years 9 months ago #123432
Replied by Todd Zuercher on topic Performance difference between Mesa 6i24 / 6i25?
I don't think there would be any difference in thread performance. That is more dependent on the PC.
The following user(s) said Thank You: 0ddbod
7 years 9 months ago #123625
Replied by andypugh on topic Performance difference between Mesa 6i24 / 6i25?
I think I would be considering the 6i24 + 7i44. (This is what I have driving the 8i20s in my lathe, but I also needed the 7i49 resolver card, so had no choice about using a 50-pin card)
Have you checked that smart-serial on the 7i85 is possible? (It certainly won't be as neat to wire as with the 7i44 or 7i74)
- 0ddbod
- Topic Author
7 years 9 months ago #123651
by 0ddbod
Replied by 0ddbod on topic Performance difference between Mesa 6i24 / 6i25?
Thanks for the comments guys,
I've not specifically asked if the 7i85 supports smart serial but the manual for it does say that it can easily interface to Mesa serial i/o devices including the 8i20 drive. For sure it wouldn't be as neat as having both ends just plug in with a cat5/6 cable.
- vre
- Thank you received: 17
7 years 9 months ago #123879
by vre
Replied by vre on topic Performance difference between Mesa 6i24 / 6i25?
Which mesa card can achieve faster servo thread
5i24 vs 6i24 vs 7i80hd ?
- Thank you received: 5334
7 years 9 months ago #123898
Replied by PCW on topic Performance difference between Mesa 6i24 / 6i25?
You can typically run a servo thread faster on a PCI or PCIE card than a Ethernet card
You can typically run a Ethernet card at about 4 KHZ with a fast host PC
The same host will typically run up to say 8 KHz with a PCI/PCIE card
8 KHz is probably not practical with most sserial cards however. 4 KHz is a typical upper limit when you have sserial cards.
The following user(s) said Thank You: vre
Time to create page: 0.054 seconds
