- Thank you received: 21
connect raspberry via ehternet as IO-port - some developer help needed
andypugh wrote: Put it in the same folder as another driver, then copy the makefile entries for that other driver.
That is all I have ever done.
Have you tried compiling and installing it with halcompile?
I've tried so.... in several ways. But it does not work.
Do you mean the Makefile or the Submakefile?
I never used autogen, autoconf or configure in development.
But I think, if it should be re-distributable, it is necessary, to include it in
these scripts.
Halcompile I used serveral years ago - but I think it is not the right tool
for writing a driver. (maybe I'm wrong...)
wicki wrote: Halcompile I used serveral years ago - but I think it is not the right tool
oh, of course I'm wrong....
It seems to work with halcompile!
halcompile --compile hal_rasPI.c
Compiling realtime hal_rasPI.c
Linking hal_rasPI.so
then copy it to ../rtlib
I'll test it again.....
But the next problem:
For the integration of the raw-sockets into the driver I need
raw-socket-access. But I can't find any rtai-functions for it.
And access by the standard-API results in "Operation not permitted"
any hints ?
The Mesa card Ethernet drivers need to run with preempt-rt not rtai.
wicki wrote: If I need 3 motor-turns/cm in 16 micorsteps, I have to send 48 signals/cm.
With a latency of 1ms, a jog-speed of 20cm/second an with a latency of
100usec, 200cm/second should be possible.
appears as a lapse of thought.... but it seems to be right.
yes... it was a stupid lapse of thought.... a stupid one....
not 16 steps for 360 degree turn, 16 steps for 1.8 degrees!
so 3200 steps /turn --> 9600 steps/cm.
with 1ms latency it is incredible slow....
with 100usec its also slow....
at which speed are youre machines running?
(microstepping by parport?)
andypugh wrote: Which realtime kernel are you using?
I made tests with vanilla, preempt and rtai 3.5 and 5.1i.
last try with kernel 4.9.80-rtai does not start (crash at kernel-boot)
